Add the following environment variable to Tomcat.
GEONETWORK_DB_NAME=/path/to/db/db_name
Where /path/to/db is the directory where you want to place the H2 database and db_name is the database name (default value is gn).
Depending on your distributions there are some options to define the variable.
You could:
* Option 1:create a setenv.sh file next to $TOMCAT_HOME/bin/catalina.sh and define the var there.
* Option 2: edit /etc/default/tomcat${TOMCAT_VERSION} (/etc/default/tomcat8 for example) and add the variable there
* Option 3: if using systemd to run Tomcat as a service create a user unit for it and define the variable there.
You can check https://www.geocat.net/docs/geonetwork-enterprise/2023/install/tomcat.html#__tabbed_1_3 for more info.
Best regards,
Juan Luis.
Juan Luis Rodriguez Ponce
E-mail: juanluisrp@anonymised.com
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31318416664
---- On Thu, 14 Mar 2024 14:10:26 +0100 Giovanni Manghi via GeoNetwork-users <geonetwork-users@lists.sourceforge.net> wrote ---
On Wed, Mar 6, 2024 at 6:24 PM Giovanni Manghi <mailto:giovanni.manghi@anonymised.com>
wrote:
I have a very small GN installation (not docker,
geonetwork-bundle-4.2.5-0) that works fine, but now I need to move it to a
different server.
Answering to myself, I found the solution reading this
https://stackoverflow.com/a/56835997
The problem is that the bundle I used to deploy GN wants to write in a
folder
/var/lib/tomcat9
which is not writeable by default by tomcat (nor exists in the first
place). I have not found any reference about this in GN docs, but I may
have overlooked something.
cheers
-- G --
GeoNetwork-users mailing list
mailto:GeoNetwork-users@lists.sourceforge.net
