abel.ludba@anonymised.com wrote:
Hello Mark
Thank you for your HowTO : setting up GN -Ubuntu.
I followed the steps you mentioned in your tutorial to install a customized Geonetwork application (I'm calling it MEGAPHONE).
Unfortunately, it dose not work, and it seems I miss a lot of steps (they must be obvious for you).
in the log off appache, I got this error message:[Fri Oct 17 11:33:30 2008] [notice] caught SIGWINCH, shutting down gracefully
[Fri Oct 17 11:33:33 2008] [notice] Apache/2.2.8 (Ubuntu) mod_jk/1.2.25 PHP/5.2.4-2ubuntu5.3 with Suhosin-Patch configured -- resuming normal$
[Fri Oct 17 11:33:49 2008] [error] [client 10.52.58.3] File does not exist: /var/www/geonetwork/web/images, referer: http://10.52.92.117/CSS/$
[Fri Oct 17 11:33:50 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/images, referer: http://megaphone.crchum$
[Fri Oct 17 11:33:50 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/script, referer: http://megaphone.crchum$
[Fri Oct 17 11:34:00 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/srv, referer: http://megaphone.crchum.qc$
[Fri Oct 17 11:34:04 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/srv, referer: http://megaphone.crchum.qc$
[Fri Oct 17 11:34:19 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/images, referer: http://megaphone.crchum$
[Fri Oct 17 11:34:19 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/script, referer: http://megaphone.crchum$
[Fri Oct 17 11:34:22 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/images, referer: http://megaphone.crchum$
[Fri Oct 17 11:34:22 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/script, referer: http://megaphone.crchum$
[Fri Oct 17 11:34:23 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/images, referer: http://megaphone.crchum$
[Fri Oct 17 11:34:23 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/script, referer: http://megaphone.crchum$
[Fri Oct 17 11:34:24 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/images, referer: http://megaphone.crchum$
[Fri Oct 17 11:34:24 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/script, referer: http://megaphone.crchum$
[Fri Oct 17 11:34:25 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/images, referer: http://megaphone.crchum$
[Fri Oct 17 11:34:25 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/script, referer: http://megaphone.crchum$
[Fri Oct 17 11:35:12 2008] [notice] caught SIGWINCH, shutting down gracefully
[Fri Oct 17 11:35:17 2008] [notice] Apache/2.2.8 (Ubuntu) mod_jk/1.2.25 PHP/5.2.4-2ubuntu5.3 with Suhosin-Patch configured -- resuming normal$
[Fri Oct 17 11:35:21 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/geonetwork/images/bg.gif, referer: http:$
[Fri Oct 17 11:35:21 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/geonetwork/script, referer: http://megap$
[Fri Oct 17 11:35:26 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/geonetwork/goenetwork
[Fri Oct 17 11:35:33 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/geonetwork/srv, referer: http://megaphon$
[Fri Oct 17 11:35:37 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/geonetwork/srv, referer: http://megaphon$
[Fri Oct 17 11:35:39 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/geonetwork/srv, referer: http://megaphon$
[Fri Oct 17 11:36:23 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/geonetwork/srv, referer: http://megaphon$
[Fri Oct 17 11:36:30 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/geonetwork/srv, referer: http://megaphon$
[Fri Oct 17 11:50:03 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/geonetwork/srv, referer: http://megaphon$
[Fri Oct 17 11:50:17 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/geonetwork/srv, referer: http://megaphon$
[Fri Oct 17 11:50:21 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/geonetwork/srv, referer: http://megaphon$
[Fri Oct 17 11:52:25 2008] [error] [client 10.120.2.15] File does not exist: /var/www/geonetwork/web/geonetwork/srv, referer: http://megaphon$Could you please help?
Thanks
Abel
Abel,
The HowTo was written for 2.1, but I've just run through it for 2.2 and
it has worked for me. I'm curious to know what steps you feel are missing.
Looking at your logs, this seems to be a bad mapping between the request
to apache and the request to tomcat. Try accessing your app directly
through tomcat using something like http://localhost:8180/geonetwork/
and see what you get.
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
