[GeoNetwork-users] Problem with map
I have configured Geonetwork 1.2.1 in suse 9.0 but when I try to view a map a next message occurs: "Sorry, error connecting to the map server"
The record "online resource" has configured as follows:
Linkage: http://simon/cgi-bin/wms?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=abastecimientos_sagunto,Comunicaciones_Sagunto,construccion_pun_sagunto,construccion_sup_sagunto,hidrografia_lin_sagunto,hidrografia_pun_sagunto,limites_admin_sagunto&STYLES=&SRS=EPSG:23030&BBOX=719500.0,4388832.887077997,741400.0,4404767.112922002&WIDTH=859&HEIGHT=625&FORMAT=image/png&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_xml
Protocol:
OpenGIS Map service (ver 1.1.1)
Function:
information
Name:
Mapserver
Any idea?
Thaks in advance.
  José Vicente Higón
  gvSIG development Team
  Conselleria de Infraestructuras y Transporte
  Generalitat Valenciana
  Valencia - Spain
  tlf. 963862397
  http://www.gvsig.gva.es
The concept we followed with that is to put the link to the WMS server in the linkage, so just http://simon/cgi-bin/wms and than refer to the layer name in the name field. So it would look like:
The other fields are OK. You can add a description with the specific layer if you wish, this will be used in the full metadata preview.
You would create multiple entries to match each layer in the WMS you want to have displayed.
Hope that helps.
Ciao,
Jeroen
On 15 Jul 2005, at 08:59, José Vicente Higón Valero wrote:
Protocol:
Function:
information
Name:
Mapserver
Any idea?
Thaks in advance.
José Vicente Higón
Valencia - Spain
tlf. 963862397
SF.Net email is sponsored by: Discover Easy Linux Migration Strategies
from IBM. Find simple to follow Roadmaps, straightforward articles,
informative Webcasts and more! Get everything you need to get up to
speed, fast. http://ads.osdn.com/?ad_id=7477&alloc_id=16492&op=click
GeoNetwork-users mailing list
