Dear Geonetwork users,
I'm a new user of Geonetwork software and I'm implementing a set of metadata associated to my Agency sources, which are files of numerical simulations, documents, etc.
I've a problem in associating a source of data, namely a file to be downloaded, to a metadata record generated by means of Geonetwork software.
As an example, I refer to the download service embedded in this metadata file (https://data.apps.fao.org/map/catalog/srv/eng/catalog.search#/metadata/5a1ea405-3c17-48d3-9ddb-da284bcdeb90)
Our IT support service has installed the software version 4.2.5.0 and I use it to input metadata records through the administrator interface.
In particular, I would like to activate the download function for the sources associated to the metadata. The sources data files to be downloaded are stored in an area of our cluster, a filesystem, which is not the same where Geonetwork is installed, so I need to specify the path to reach those files.
Unfortunately I cannot found how to activate the download service by means the Geonetwork interface when I'm filling in the metadata templates, nor I'm able to activate it from the administrator setting.
Can you share with me your experience with the download services, in metadata files, through Geonetwork?
Any suggestion is welcome.
With best regards
Elena Gianesini
[logo-ArpaFVG_v]
ARPA FVG
Centro Regionale Modellistica Ambientale
Elena Gianesini
tel 0432 191 8049
Via Cairoli, 14, 33057 Palmanova (UD)
AVVISO DI RISERVATEZZA
"Informazioni riservate possono essere contenute nel messaggio o nei suoi allegati. Se non siete i destinatari indicati nel messaggio, o responsabili per la sua consegna alla persona, o se avete ricevuto il messaggio per errore, non dovete trascriverlo, copiarlo o inviarlo a nessuno. In tal caso, dovete cancellare/distruggere il messaggio ed i suoi allegati. Grazie."
CONFIDENTIALITY NOTICE
"Confidential information may be contained in this message or in its attachments. If you are not the addressee indicated in this message, or responsible for message delivering to that person, or if you have received this message in error, you may not transcribe, copy or deliver this message to anyone. In that case, you should delete/destroy this message and its attachments. Thank you".
AVVISO DI RISERVATEZZA Informazioni riservate possono essere contenute nel messaggio o nei suoi allegati. Se non siete i destinatari indicati nel messaggio, o responsabili per la sua consegna alla persona, o se avete ricevuto il messaggio per errore, siete pregati di non trascriverlo, copiarlo o inviarlo ad alcuno. In tal caso vi invitiamo a cancellare il messaggio ed i suoi allegati. Grazie.
CONFIDENTIALITY NOTICE Confidential information may be contained in this message or in its attachments. If you are not the addressee indicated in this message, or responsible for message delivering to that person, or if you have received this message in error, you may not transcribe, copy or deliver this message to anyone. In that case, you should delete this message and its attachments. Thank you.
(attachments)
