I want to modify CSW output (brief) for ISO 19139 and have changed the file iso-brief.xsl in the directory schema_plugins\iso19139\present\csw, as advised in the documentation. But this change has no effect (even after restarting tomcat). You can even delete iso-brief.xsl, the CSW output does not change. Did I miss something? Have you any idea?
I'm running Geonetwork 3.0.3.0
Thank you in advance,
best regards
Gerhard
Priv.-Doz. Dr. Gerhard Gröger
CPA Software GmbH
Auf dem Seidenberg 3a
53721 Siegburg
Tel.: +49 2241 2594-241
Fax.: +49 2241 2594-29
groeger@anonymised.com
www.cpa-software.de
Handelsregister:
HRB 12438, Amtsgericht Siegburg
Geschäftsführer:
Dr.-Ing. habil. Christoph Averdung
Dr.-Ing. Matthias Ellsiepen
Hi Gerd,
either you're working in the wrong directory or you have to make a new build. Maybe my schema problems are of help to you: https://github.com/geonetwork/core-geonetwork/issues/1114
Christian
Am 21.06.2016 um 15:50 schrieb Gerd Gröger:
best regards
Gerhard
Hi Christian,
thank you for your reply. Since the directory is correct, I currently try to make a new build. I initially hoped that a new build is not necessary if only an xslt file is modified....
best regards
Gerd
Am 21.06.2016 um 16:20 schrieb Christian Seip:
Hi Gerd,
Christian
best regards
Gerhard
CPA Software GmbH
53721 Siegburg
www.cpa-software.de
Handelsregister:
Geschäftsführer:
