Using svn trunk, when I attempt to harvest the same OGC WxS URL as a
different service type, I get a "Duplicate entry" Java stack error when
hovering over the error icon.
We have a single URL which serves out WMS, WFS, WCS and SOS. So yes, it
is the same URL, but interacts differently depending on the interface.
Any suggestions on how this can be handled?
Thanks
..Tom
Hello Tom,
I can't reproduce the issue ... are you using mckoi db ?
You could be right due to the idea to use the url as an identifier in
order to be able to update the metadata in the catalogue even if
generated from the capabilities document (not supported yet but
discussed last year off list with some people).
Could you post the full stack error ?
I would suggest to fixed that generating the uuid based on the full URL
with parameters and not only the service connect point.
Francois
Thanks
