Hi Francois-Xavier, thanks for this information: I must have been looking
into the wrong doc folder or an obsolete version of the admin guide. The
use of the thesaurus and the purpose of the administration or clear to me
know.
Joeri
Francois-Xavier Prunayre <francois-xavier.prunayre@anonymised.com>
14/11/2007 12:04
To
Joeri.Theelen@anonymised.com
cc
geonetwork-users@lists.sourceforge.net
Subject
Re: [GeoNetwork-users] Purpose of thesauri management application
Hi Joeri, in the doc directory you should have the admin guide. In that
guide, you'll have a full description of thesaurus managment in
GeoNetwork.
The thesaurus of type place is not really useful you're right because
the information is in the DB. But we made test using Agrovoc Thesaurus
and others. You could upload Agrovoc in GeoNetwork. Then the editor will
help you selecting keywords.
http://geonetwork.svn.sourceforge.net/viewvc/*checkout*/geonetwork/branches/2.1.x/docs/manuals/admin-guide.pdf
There's quite a lot of other issues on thesaurus managment
(multilingual, store id instead of name) which have been discussed on
the dev mailling list
http://www.nabble.com/forum/Search.jtp?forum=18419&local=y&query=thesaurus
and during the last workshop.
HTH. Francois
Joeri.Theelen@anonymised.com wrote:
I'd like to know what the purpose is of the thesaurus management
application integrated in the Geonetwork administrator part.
It allows you to manage the content of 5 RDF/SKOS thesauri, external or
local, but:
- only the thesaurus of type "place" is available, i.e. the file
"regions.rdf";
- its content matches the content of these 2 related tables "regions"
and
"regionsdes" in the Geonetwork catalogue database, but as far as I can
tell, there is no relation between the local RDF file and the content of
these tables...?
- the RDF file (XML) is not referenced by any of the XML Schema's
(ISO-19115, ISO-19139,...) or metadata instances (for validation
purposes).
In short, I do not understand the purpose of the thesaurus management
application with regard to the Geonetwork catalogue.
Probably, it is to be considered a separate application that happens to
be
integrated in Geonetwork.
I cannot find any explanation on this in the Geonetwork documentation,
user lists, developer lists etc.
Joeri
GeoNetwork-users mailing list
Francois Xavier Prunayre
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
Tel : + 33 (0)6 34 11 71 75
http://www.camptocamp.com
