[GeoNetwork-users] Re-order tabs in metadata editor By Package view mode - GN v2.10.2 HTML5UI
I'd like to re-order the tabs in the metadata editor By Package view mode.
For example currently 'Metadata' is the first tab displayed on the left. Is
it possible for the 'Identification' tab to appear first instead?
I have had no luck with the changes I have tried so far and was hoping
someone could point me in the right direction please (I have a feeling I've
been mucking around with the wrong files).
Any help would be much appreciated.
Kind regards
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-order-tabs-in-metadata-editor-By-Package-view-mode-GN-v2-10-2-HTML5UI-tp5141061.html
In reply to my own post in case anyone else is interested in doing a similar
thing.
I was changing the correct files (see below) however needed to do a system
stop start for the changes to become effective (rookie mistake).
schema_plugins/iso19139/present/metadata-edit.xsl
schema_plugins/iso19139/present/metadata.xsl
Kind regards
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-order-tabs-in-metadata-editor-By-Package-view-mode-GN-v2-10-2-HTML5UI-tp5141061p5141285.html
