I installed Geonetwork in Ubuntu using tomcat, behind HTTP proxy , however
it fails to start. It redirects to
https://mydomain/geonetwork/signin?node=@@nodeId@@
I downloaded the war file and put in /var/lib/tomcat8/webapps and
followed instructions:
https://www.geonetwork-opensource.org/manuals/trunk/en/maintainer-guide/production-use/index.html#java-container
Also, changed the database to point to postgis and added proxy behind
apache :
ProxyPass / ajp://localhost:8009/geonetwork/
ProxyPassReverse / ajp://localhost:8009/geonetwork/
Any thoughts?
Thanks.
We have fixed it already in gitter.im/geonetwork channel
Just for the records, proxy configuration should be
ProxyPass /geonetwork ajp://localhost:8009/geonetwork
ProxyPassReverse /geonetwork ajp://localhost:8009/geonetwork
Juan Luis.
On Wed, May 6, 2020 at 6:09 AM Alireza Shamakhy <alireza.shamakhy@anonymised.com>
wrote:
apache :
Any thoughts?
Thanks.
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Juan Luis Rodríguez.
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
