Hi!
I want to setup a new Ubuntu 24 server with Geonetwork and Geoserver
(latest versions).
I want to use tomcat as servlet container. I understand that Tomcat 9 is
compatible with both.
However, Geonetwork needs Java 8 and Geoserver needs Java 11.
I can install both Java versions, but the problem is to point Geonetwork to
the Java 8 instance.
I have had such a setup running for more than a year, but it suddenly
defaulted to Java 11, which stopped Geonetwork from running. I found no way
to force Geonetwork to the Java 8 instance.
So I decided to start with a new machine, and get it right from the start.
Both ChatGPT and Gemini suggests parallel Tomcat instances, but I was
hoping that there would be a simpler configuration issue.
Regards, Mats Elfström
*GisKraft*, Geodatakonsult
Mats Elfström, Marsvinsholms stationsväg 80, 271 93 Ystad, Sweden
tel: +46 70 595 39 35 / www.giskraft.se
If you are using the latest version of GeoNetwork (4.4) you can us Java 11 for both.
Byron Cochrane
OpenWork Ltd
Nelson, New Zealand
byron@anonymised.com
+64 21 794 501
https://www.openwork.nz/
“The whole problem with the world is that fools and fanatics are so certain of themselves, yet wiser people so full of doubt” - Bertrand Russell
"Never doubt that a small group of thoughtful, committed citizens can change the world; indeed, it's the only thing that ever has.” - Margaret Mead
On 5 Aug 2024, at 2:20 AM, Mats Elfström via GeoNetwork-users <geonetwork-users@lists.sourceforge.net> wrote:
Hi!
(latest versions).
GeoNetwork-users mailing list
Thanks Byron!
That is great information! I will certainly go for that.
Sorry I looked no further than v4.2 and did not know that the Java issue
had been resolved.
Regards, Mats.E
Den mån 5 aug. 2024 kl 01:38 skrev Byron Cochrane <byron@anonymised.com>:
for both.
Byron Cochrane
!openwork_favicon__white96x96.png|96x96
OpenWork Ltd
Nelson, New Zealand
+64 21 794 501
Margaret Mead
Hi!
(latest versions).
