Dear list,
I recently sent a question about the WFS service not accessible to external users after migrating to version 3.12. I see now that CSW is not accessible neither! This is quite annoying as the INSPIRE monitoring is coming soon...
I see in the log: <ows:ExceptionText>OperationNotAllowedEx : Operation not allowed</ows:ExceptionText>.
After further check I see that I can't even change any settings inside geonetwork UI. I have the green block saying that settings change have been saved but if I refresh nothing is changed.
In the log, I see quite a lot of errors. For instance:
2021-11-23 09:30:55,133 ERROR [jeeves] - Unexpected problem completing transaction, will try to rollback
org.springframework.dao.DataIntegrityViolationException: not-null property references a null or transient value : org.fao.geonet.domain.MetadataStatus.uuid; nested exception is org.hibernate.PropertyValueException: not-null property references a null or transient value : org.fao.geonet.domain.MetadataStatus.uuid
2021-11-23 09:22:02,077 ERROR [jeeves.webapp.csw] - Cannot get schema file : /opt/tomcat9/webapps/geonetwork/xml/validation/csw202_apiso100/csw/2.0.2
2021-11-22 23:03:03,837 ERROR [jeeves.service] - Exception executing gui service : org.springframework.orm.jpa.JpaSystemException: could not execute query; nested exception is org.hibernate.exception.GenericJDBCException: could not execute query
Caused by: org.h2.jdbc.JdbcSQLException: IO Exception: "java.io.IOException: org.h2.jdbc.JdbcSQLException: IO Exception: ""Missing lob entry, block: 602342"" [90028-174]"; "lob: null table: -1 id: 127071" [90031-174]
Any idea what I could do? Is it a known GN version issue?
Many thanks for your help,
Nicolas
Nicolas de Ville
Belgian Marine Data Centre (BMDC)
OD-Nature, Royal Belgian Institute of Natural Sciences
02/627.42.79
www.bmdc.be
https://metadata.naturalsciences.be/
