Do i need to install this geonetwork as user tomcat or i just change the
mode og geonetwork directory?
The current rights are set as 0755
regards
simon
Hi
Can tomcat read and write the directories where geonetwork is installed?
2009/4/18 <sysadmin@anonymised.com>
---------------------------- Original Message ----------------------------
Subject: [Fwd: now i step forward is noticed for geonetwork installation]
Date: Sat, April 18, 2009 9:11 am
To: geonetwork-users@lists.sourceforge.net
Cc: "Pedro Monteiro" <monteiro.s.pedro@anonymised.com>
look tomcat seem to behave on http://66.96.201.221:8080/ though i have
not done so much apart from what Pedro directed me .
Does this indicate i can now install geonetwork 2.2.0 ?
Java is already installed at /opt/java/jdk1.6.0_18 and is set as the default
displaying the following
[root@anonymised.com ~]# java -version
java version "1.6.0_14-ea"
Java(TM) SE Runtime Environment (build 1.6.0_14-ea-b03)
Java HotSpot(TM) Client VM (build 14.0-b12, mixed mode, sharing)
regards
simon
Subject: now i step forward is noticed for geonetwork installation
Date: Sat, April 18, 2009 5:36 am
Hey Pedro,
Tomcat now looks to respond to the port 8080 that is on this link
http://66.96.201.221:8080 but as soon as i have installed Geonetwork and
installed very well and configured tomcat file SERVER.XML where i have
fixed the path for Geonetwork,Geoserver and intermap that is within host
element BUT when i try to browse this http://66.96.201.221:8080/geonetwork
IT SEEM NOT TO GO ANYWHERE and EVEN TOMCAT HAS GONE OFF(not showing).
bUT i have noticed a echo from the shell as follow
/opt/java/jdk1.6.0_14/bin/java -jar geonetwork-install-2.2.0.j
ar
Exception in thread "AWT-EventQueue-0"
javax.swing.text.StateInvariantError: Gly phView: Stale
view: javax.swing.text.BadLocationException: Length must be positi
ve
at javax.swing.text.GlyphView.getText(GlyphView.java:118)
at
javax.swing.text.GlyphView.getBreakSpotUseWhitespace(GlyphView.java:7
40)
at javax.swing.text.GlyphView.getBreakSpot(GlyphView.java:732)
at javax.swing.text.GlyphView.getBreakWeight(GlyphView.java:670)
at
javax.swing.text.html.InlineView.getBreakWeight(InlineView.java:136)
at
javax.swing.text.FlowView$FlowStrategy.layoutRow(FlowView.java:508)
at javax.swing.text.FlowView$FlowStrategy.layout(FlowView.java:460)
at javax.swing.text.FlowView.layout(FlowView.java:184)
at javax.swing.text.BoxView.setSize(BoxView.java:380)
at javax.swing.text.BoxView.updateChildSizes(BoxView.java:349)
at javax.swing.text.BoxView.setSpanOnAxis(BoxView.java:331)
at javax.swing.text.BoxView.layout(BoxView.java:691)
at
javax.swing.plaf.basic.BasicTextUI$RootView.setSize(BasicTextUI.java:
1702)
at
javax.swing.plaf.basic.BasicTextUI$RootView.paint(BasicTextUI.java:14
21)
at
javax.swing.plaf.basic.BasicTextUI.paintSafely(BasicTextUI.java:722)
at javax.swing.plaf.basic.BasicTextUI.paint(BasicTextUI.java:869)
at javax.swing.plaf.basic.BasicTextUI.update(BasicTextUI.java:848)
at javax.swing.JComponent.paintComponent(JComponent.java:763)
at javax.swing.JComponent.paint(JComponent.java:1029)
at javax.swing.JComponent.paintChildren(JComponent.java:864)
at javax.swing.JComponent.paint(JComponent.java:1038)
at javax.swing.JViewport.paint(JViewport.java:747)
at javax.swing.JComponent.paintToOffscreen(JComponent.java:5124)
at
javax.swing.BufferStrategyPaintManager.paint(BufferStrategyPaintManag
er.java:277)
at javax.swing.RepaintManager.paint(RepaintManager.java:1220)
at javax.swing.JComponent._paintImmediately(JComponent.java:5072)
at javax.swing.JComponent.paintImmediately(JComponent.java:4882)
at
javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:803)
at
javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:714)
at
javax.swing.RepaintManager.seqPaintDirtyRegions(RepaintManager.java:6
94)
at
javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(System
EventQueueUtilities.java:128)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at
java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThre
ad.java:269)
at
java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.
java:184)
at
java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThre
ad.java:174)
at
java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at
java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Am wondering if Java is the one that has a PROBLEM OR IS THE tOMCAT that
is not fully configured against Geonetwork.
Is there anybody with a way forward.
Regard
Simon
Well I've never managed to get it working with the tomcat rpm package, as
it
uses gcj and gives some problems.Try a tomcat install as explained in
http://geoserver.org/display/GEOSDOC/1.1.4+CentOS+(Red+Hat)+5.1+Install.Hope it helps,
2009/4/17 <sysadmin@anonymised.com>
Dear Pedro Monteiro,
Surely now am almost confused but before i get totally confused may be
you
could sort me outI have been working with centos 5.2
1. I have been installing java
jdk-6u14-ea-bin-b03-linux-i586-10.bin
which out put this as the version installed as the default 1.6.0_14-ea2. I have also been installing tomcat5 through yum install tomcat5
which have been installing very well as i can been able to start and
stop
it3. I have been installing Geonetwork version 2.2.0 which have been
installing some how well but have never configured MSQL database with
GASTAfter this the only file that i do configure is the server.xml for the
tomcat5 under host i normally fix the content for geonetwork , Geoserver
and
for intermapAfter this i normally set tomcat to start as a service with the
chkconfig
commandbut when i try to launch my geonetwork on this
http://66.96.201.221:8080/geonetwork it never comei surely don't what have not been configured upto now
looking for your advice
Regards
simon----- Original Message -----
From: "Pedro Monteiro" <monteiro.s.pedro@anonymised.com>
To: "simon .K.M" <simon@anonymised.com>
Cc: <geonetwork-users@lists.sourceforge.net>
Sent: Friday, April 17, 2009 1:26 PM
Subject: Re: [GeoNetwork-users] Geonetwork manual for centos 5.2> Hello
> I've configured on server with geonetwork. What kind of problems are
you
> having?
> 2009/4/17 simon .K.M <simon@anonymised.com>
>> Dear all,
>> Is there anybody who have ever configured geonetwork on centos5.2.
>> regards
>> Web Designer
>> ERMIS Africa
>> P.O. Box 17347
>> Nakuru-20100
>> Kenya
>> Tel:254-51-2213323
>> Fax:254-51-2214536
>> Cell Phone +254 725 885 889
>> E-mail:simon@anonymised.com <E-mail%3Asimon@anonymised.com> <
E-mail%3Asimon@anonymised.com <E-mail%253Asimon@anonymised.com>>
>> Website:http://www.ermisafrica.org
>> http://www.ermisafrica.com
>> Stay on top of everything new and different, both inside and
>> around Java (TM) technology - register by April 22, and save
>> $200 on the JavaOne (SM) conference, June 2-5, 2009, San Francisco.
>> 300 plus technical and hands-on sessions. Register today.
>> Use priority code J9JMT32. http://p.sf.net/sfu/p
>> _______________________________________________
>> GeoNetwork-users mailing list
>> GeoNetwork-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
>> GeoNetwork OpenSource is maintained at
>> http://sourceforge.net/projects/geonetwork
> http://sourceforge.net/projects/geonetwork--------------------------------------------------------------------------------
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.238 / Virus Database: 270.11.59/2064 - Release Date:
04/17/09
07:08:00
