Here the xml of your metadata:
http://ccwbvps01.in2p3.fr:8080/geonetwork/srv/eng/xml.metadata.get?id=13285
We can see the CRS codes. The editor might be slow because it has to load
and render all form components for those CRS.
How did you get this metadata ?
What do you mean by sheet with spatial data, or without ?
Is it a metadata of service that you got from geoserver harvesting ?
Either you could change your geoserver configuration to show less supported
CRS, or you can edit your medata in XML view and remove all useless CRS ..
or we need to change the way the harvesting is processed
On Tue, May 26, 2015 at 3:27 PM, Georges H <georges.hinot@anonymised.com> wrote:
Hello everyone, and thank you for your advice, which already helped me a
lot.
I still have my slow problem on GeoNetwork3, when I am creating, publishing
and full view of a metadata-sheet from a layer with spatial data.
I installed 2 GN3, on different machines, with different configurations and
different Posgtres versions, to see if the problem was from a configs. But
not, the two have this problem of slowness.
I think the problem is from a "Reference System Information" field, because
in full view of a sheet, I can see several thousands of CRS about my layer.
But I have made no !
When I create a sheet without spatial data, I have no problem.
Can you help me ?
Here an example of a problem sheet :
http://ccwbvps01.in2p3.fr:8080/geonetwork/srv/eng/catalog.search#/metadata/a8141dbf-030a-43e3-ae10-93344295c628
Thank you !
*Georges Hinot*
*CNRS - DRIIHM - UMS BBEES (3468)*
Musée d'Histoire Naturelle de Paris, Maison Buffon
Géomaticien - Administrateur BDD - Intégrateur
*Tél : 01 40 79 80 44*
*Tél : 06 47 61 84 92*
Le nouveau site DRIIHM-ROHM ! <http://driihm.fr>
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
Application Monitoring Software and Tool - ManageEngine Applications Manager
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
Florent Gravin
Camptocamp - Chambéry
0479444492
