[GeoNetwork-users] Source code for older GeoNetwork versions
Hello,
Im trying to find a way to download the source code for an older GeoNetwork version, specifically version 3.12.1, to start a project with that particular version where I can also modify the source code afterwards. I have tried the corresponding zip bundle, but it doesn't seem to be what I am looking for as I want to be able to build the full project using Maven and deploy my own version to a Tomcat instance. In the meantime I have deployed the provided .war file for this version in Tomcat, but again, being able to customize the project would be much better. Is there any place to find the full source code for old versions, in the same vein of cloning the github repository for the latest release?
Thanks in advance,
Facundo Pedreira
Servicio de Geomática
Intendencia de Montevideo
El presente correo electronico y cualquier posible archivo adjunto esta dirigido unicamente al destinatario del mismo y contiene informacion que puede ser confidencial. Si Ud. no es el destinatario correcto por favor notifique al remitente respondiendo este mensaje y elimine inmediatamente de su sistema, el correo electronico y los posibles archivos adjuntos al mismo. Esta prohibida cualquier utilizacion, difusion o copia de este correo electronico por cualquier persona o entidad que no sean las especificas destinatarias del mensaje. La Intendencia de Montevideo no acepta ninguna responsabilidad con respecto a cualquier comunicacion que haya sido emitida incumpliendo nuestra normativa municipal, asi como lo previsto en la Ley 18.331 de Proteccion de Datos Personales y la Ley 18.381 de Acceso a la Informacion Publica.
This e-mail and any attachment is confidential and is intended solely for the addressee(s). If you are not intended recipient please inform the sender immediately, answering this e-mail and delete it as well as the attached files. Any use, circulation or copy of this e-mail by any person or entity that is not the specific addressee(s) is prohibited. The City Council of Montevideo is not responsible for any communication emitted without respecting our Organization Policy or the Data Protection Act and Habeas Data Action No. 18.331 and the Information Access Act N 18.381.
Hello Facundo
If you clone the https://github.com/geonetwork/core-geonetwork/ repository, you have a branch for each minor version of geonetwork. It goes way beyond your needs, down to GN 2 versions. You will easily find the 3.12.x branch
And if you want a very specific tag, there are also git tags on every version that was released
Best regards,
Jean
*Jean Pommier -- pi-Geosolutions*
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com
Web : www.pi-geosolutions.fr <http://www.pi-geosolutions.fr>
linkedin : jean-pommier <https://www.linkedin.com/in/jean-pommier/&gt;
Le 28/03/2023 à 17:40, facundo.pedreira--- via GeoNetwork-users a écrit :
Hello,
Thanks in advance,
Facundo Pedreira
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained athttp://sourceforge.net/projects/geonetwork
Should be what you look for:
https://github.com/geonetwork/core-geonetwork/archive/refs/tags/3.12.1.zip
On Tue, Mar 28, 2023 at 6:17 PM Jean Pommier via GeoNetwork-users <
geonetwork-users@lists.sourceforge.net> wrote:
Hello Facundo
If you clone the GitHub - geonetwork/core-geonetwork: GeoNetwork is a catalog application to manage spatially referenced resources. It provides powerful metadata editing and search functions as well as an interactive web map viewer. It is currently used in numerous Spatial Data Infrastructure initiatives across the world.
the 3.12.x branch
Best regards,
Jean
> Hello,
> Thanks in advance,
> Facundo Pedreira
> geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
*Technical Leader - Architect*
+33 4 58 48 20 36
