do you know if the SPARQL query feature is implemented?
ref. http://trac.osgeo.org/geonetwork/wiki/proposals/DCATandRDFServices#SPARQLqueries
I GN 2.10.1 http://localhost:8080/geonetwork/srv/eng/rdf.search?any= is working for free-text search, but so far has none SPARQL queries succeeded (I'm a SPARQL rookie).
http://localhost:8080/geonetwork/srv/eng/rdf.metadata.get?uuid= is also working.
I'm trying to integrate with Apache Marmotta LD-Path and LD-Caching.
kind regards
Jørn-Vegard Røsnes
CONFIDENTIALITY
This e-mail and any attachment contain KONGSBERG information which may be
proprietary, confidential or subject to export regulations, and is only meant
for the intended recipient(s). Any disclosure, copying, distribution or use is
prohibited, if not otherwise explicitly agreed with KONGSBERG. If received in
error, please delete it immediately from your system and notify the sender
properly.
2013/8/2 Jørn Vegard Røsnes <jorn@anonymised.com>:
In that proposal, an RDF/DCAT output was added in order to harvest
GeoNetwork in a SPARQL endpoint like Virtuoso which then provides
SPARQL query support
Cheers.
Francois
kind regards
Jørn-Vegard Røsnes
CONFIDENTIALITY
properly.
Get your SQL database under version control now!
Version control is standard for application code, but databases havent
caught up. So what steps can you take to put your SQL databases under
version control? Why should you start doing it? Read more to find out.
http://pubads.g.doubleclick.net/gampad/clk?id=49501711&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
