[GeoNetwork-users] Spatial Reference System of the Intermapviewer
Thank you for your reply. Is there a tutorial to integrate OpenLayers into Geonetwork?
regards Albert
Von: Jeroen Ticheler <Jeroen.Ticheler@anonymised.com>
An: Albert Krueger <albert79@anonymised.com>
Betreff: Re: [GeoNetwork-users] Spatial Reference System of the Intermapviewer
Datum: Wed, 11 Feb 2009 23:25:17 +0100
That's right. The WMS specification mandates the support of WGS84. For
a generic client that should be able to operate on WMS's from all over
the place that choice is thus a safe option. That justifies the choice
not to worry to much about the SRS :slight_smile: . You can indeed integrate
other clients if you require support for projections.
Ciao,
Jeroen
On Feb 11, 2009, at 4:07 PM, Pickering, Jason wrote:
> Someone correct me if I am wrong, but I believe that intermap is not
> aware of projection systems other than WGS84. It assumes that
> everything is WGS84, even if it is not.
> If you need to display it in that SRS, you will need to use another
> client (e.g. OpenLayers, MapFish, etc)
> -----Original Message-----
> From: Albert Krueger [mailto:albert79@anonymised.com]
> Sent: Wed 2009-02-11 15:28
> To: geonetwork-users@lists.sourceforge.net
> Subject: [GeoNetwork-users] Spatial Reference System of the
> Intermapviewer
> Hi everybody,
> how can I change the Spatial Reference System of the Intermap viewer
> so that my interactive map is displayed in SRS = 31467?
> The GeoServer SRS is correctly defined in the FeatureType editor and
> is displayed correctly when I choose the Map Preview on the Demo
> page of GeoServer.
> Only in GeoNetwork / Intermap it seems to me my geographic data is
> projected in WGS84.
> Thanx a lot for any advice,
> Albert
> Create and Deploy Rich Internet Apps outside the browser with
> Adobe(R)AIR(TM)
> software. With Adobe AIR, Ajax developers can use existing skills
> and code to
> build responsive, highly engaging applications that combine the
> power of local
> resources and data with the reach of the web. Download the Adobe AIR
> SDK and
> Ajax docs to start building applications today-<a target="_blank"
href='http://p.sf.net/sfu/adobe-com’>http://p.sf.net/sfu/adobe-com&lt;/a&gt;
> GeoNetwork-users mailing list
> GeoNetwork-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> GeoNetwork OpenSource is maintained at <a target="_blank"
href='http://sourceforge.net/projects/geonetwork’>http://sourceforge.net/pro
jects/geonetwork</a>
Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code
to
build responsive, highly engaging applications that combine the power of
local
resources and data with the reach of the web. Download the Adobe AIR SDK
and
LOVE@anonymised.com ist jetzt ganz neu ? melde dich kostenlos an, lerne neue Leute kennen und finde deinen Flirt! http://love.lycos.de/start.action
