Dear fellow Geonetwork-Users,
I am experimenting with the sub-portal feature of GN, but have troubles to make it work (see GN specs below).
Specifically, I want to filter a subset of existing ISO19139 and ISO19115-3 records similar to the examples given at the Portal configuration documentation <https://geonetwork-opensource.org/manuals/trunk/en/administrator-guide/configuring-the-catalog/portal-configuration.html> site like:
/+keyword:inspire or/
/+thesaurusName:"GEMET - INSPIRE themes, version 1.0"/
I tried the latter, and:
/+keyword:"Some specific search term"/ or /+keyword:term/,
/title:"Some specific title"/,
/+metadataStandard:ISO19115-3/ including variations like /…:(ISO19115-3)/ or /…:"ISO19115-3"/
/+keyword:*/ etc.,
but to no avail. The given Subportal either lists nothing or complains about bad search requests (basically all phrase searches). All the search terms exist in some of the files and entries are set to published.
I know the feature is based on Lucene and the feature not working page <https://github.com/geonetwork/core-geonetwork/issues/4727> lists "Lucene / LuceneSearcher.getMetadataFromIndexById". However the first line in Section *Features removed* states "CSW/Virtual CSW is replaced by sub-portal (see Portal configuration <https://geonetwork-opensource.org/manuals/trunk/en/administrator-guide/configuring-the-catalog/portal-configuration.html>\)" kind of indicates it should be working.
I'm out of ideas - any hint would be highly appreciated!
Thanks in advance!
Best regards,
Lars
PS: GN specs
Version: 4.0.0
Subversion: 0
DB-Backend: PostGres
ES + Kibana working fine
Dr. Lars Möller
Helmholtz-Zentrum Geesthacht
Zentrum für Material und Küstenforschung
-Modellierung zur Bewertung von Küstensystemen (KBS)
Max-Planck-Straße 1
21502 Geesthacht
Germany
Fon +49 (0) 4152- 87 - 1849
Fax +49 (0) 4152- 87 - 41849
E-mail: lars.moeller@anonymised.com
www.hzg.de
Helmholtz-Zentrum Geesthacht Zentrum für Material- und Küstenforschung GmbH Max-Planck-Straße 1 I 21502 Geesthacht I Deutschland/Germany
Geschäftsführung/Board of Management: Prof. Dr. Matthias Rehahn, Silke Simon Vorsitzender des Aufsichtsrates/Chairman of the Supervisory Board: Ministerialdirigent Engelbert Beyer Amtsgericht Lübeck HRB 285 GE (Register Court) Internet: http://www.hzg.de
