[GeoNetwork-users] tc211
Hello.
I am a complete geo metadata newbie trying to import some tc211 metadata (in xml) into geonetwork. During upload I choose iso19115 as it seem to be the best choise. Is it?
I get the following error message: "The requested operation could not be performed. Root element not set" and the following stacktrace on the server.
java.lang.IllegalStateException: Root element not set
         at org.jdom.Document.getRootElement(Document.java:218)
         at jeeves.utils.Xml.transform(Xml.java:102)
         at org.fao.geonet.kernel.DataManager.extractUUID(DataManager.java:256)
         at org.fao.geonet.services.metadata.Insert.exec(Insert.java:89)
Tried to dig into this and found web/xml/schemas/iso19115/extract-uuid.xsl that looks for Metadata/mdFileID. My metadata has MD_Metadata/fileIdentifier instead. The start of the file (I do not know if it is correct) looks like this:
<MD_Metadata
  xmlns="http://www.isotc211.org/schemas/2005/gmd&quot;
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
  xmlns:gco="http://www.isotc211.org/schemas/2005/gco&quot;
  xsi:schemaLocation="http://www.isotc211.org/schemas/2005/gmd ../gmd/gmd.xsd">
  <fileIdentifier>
    <gco:CharacterString>1234-43214321-432432-12332</gco:CharacterString>
  </fileIdentifier>
Is my file correct? Should I create a web/xml/schemas/tc211 or what?
  - Tore.
Your metadata is correct: you need only to use a prefix (say, 'gmd') instead
of the default one (this is important for the editor).
When importing the metadata, you have to choose iso19139 because
that standard is the encoding of the 19115 using xml.
The iso19115 is an old encoding with short names that is obsolete now.
Hello.
the server.
<MD_Metadata
gmd.xsd">
  <fileIdentifier>
  </fileIdentifier>
  - Tore.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier.
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
GeoNetwork-users mailing list
Hello.
Thanks! I guess I will need a newer version of geonetwork than 2.0.3 to be able to choose iso19139. Currently I can only choose iso19115, fgdc-std or dublin-core.
  - Tore.
Hello.
the server.
<MD_Metadata
gmd.xsd">
  <fileIdentifier>
  </fileIdentifier>
  - Tore.
Hi Tore,
That's correct. You'll need to get the code from the SVN to have the latest.
We are working on getting a beta release ready.
Ciao,
Jeroen
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net on behalf of Tore
Halset
Sent: Mon 2/19/2007 22:07
To: geonetwork-users@lists.sourceforge.net
Cc:
Subject: Re: [GeoNetwork-users] tc211
Hello.
  - Tore.
'gmd') instead
Hello.
the server.
(Insert.java:89)
<MD_Metadata
gmd.xsd">
  <fileIdentifier>
  </fileIdentifier>
  - Tore.
security?
job easier.
Geronimo
geonetwork-users List Signup and Options
projects/geonetwork
security?
job easier.
Geronimo
projects/geonetwork
opinions on IT & business topics through brief surveys-and earn cash
