Hi Tanja,
Generally this means that tomcat or something else is still running when
you try to restart it. You can find out what is running on the port
mentioned in your error logs by running the following command (assuming you
are on linux):
sudo fuser -v -n tcp 61616
Then you can kill the process identified by running the following
(substitute the process you had for 1234):
sudo kill -9 1234
Jo
On Thu, Aug 23, 2018 at 7:34 AM Tanja <tanja.ruecker@anonymised.com>
wrote:
Hello,
I want to use a new Version of Geonetwork. I use the .war and get a new
folder of Geonetwork in the webapps folder in the Tmocat folder. When I try
to start Geonetwork I get the following error
FATAL [jeeves.engine] - Raised exception during init
FATAL [jeeves.engine] - Exception :
org.springframework.beans.factory.BeanCreationException: Error creating
bean
with name 'org.apache.activemq.xbean.XBeanBrokerService#0': Invocation of
init method failed; nested exception is java.io.IOException: Failed to bind
to server socket: tcp://localhost:61616 due to: java.net.BindException:
Address already in use: JVM_Bind
FATAL [jeeves.engine] - Message : Error creating bean with name
'org.apache.activemq.xbean.XBeanBrokerService#0': Invocation of init method
failed; nested exception is java.io.IOException: Failed to bind to server
socket: tcp://localhost:61616 due to: java.net.BindException: Address
[jeeves.engine] - Stack :
bean
Maybe the error appear because I had an other Geonetwork version on the
server before? Can someone help me to start the Geonetwork?
Thanks.
Kind regards,
Tanja
Sent from:
http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
*Jo Cook*
t:+44 7930 524 155/twitter:@archaeogeek
Please note that currently I do not work on Friday afternoons. For urgent
responses at that time, please visit support.astuntechnology.com or phone
our office on 01372 744009
Reserve your conference place now: *Bristol 26 Sept
<https://www.eventbrite.co.uk/e/astun-conference-bristol-tickets-46763717538>\*
| *Leeds 3rd October
<https://www.eventbrite.co.uk/e/astun-conference-leeds-tickets-46763825862>
*Sign up to our mailing list
<https://astuntechnology.com/company/#email-updates> for updates on news,
products, conferences, events and training*
Astun Technology Ltd, The
Coach House, 17 West Street, Epsom, Surrey, KT18 7RL, UK
t:+44 1372 744
009 w: astuntechnology.com <http://astuntechnology.com/> twitter:@astuntech
<https://twitter.com/astuntech>
iShare - enterprise geographic
intelligence platform <https://astuntechnology.com/ishare/>
GeoServer,
PostGIS and QGIS training <https://astuntechnology.com/services/#training>
Helpdesk and customer portal
<http://support.astuntechnology.com/support/login>
Company registration
no. 5410695. Registered in England and Wales. Registered office: 120 Manor
Green Road, Epsom, Surrey, KT19 8LN VAT no. 864201149.
