I update a metadata (that is, the DATA field of the METADATA table) directly
using a sqlplus sentence (Oracle). Afterwards, I go to GN, I click in the
category where the metadata is placed and I see that the metadata content is
updated properly.
However, when I try to search that metadata using the free text search, I
don't find any matches, it seems that Lucene has not indexed that metadata.
I restart Tomcat in order that the whole catalogue will be indexed again but
I get the same behavior.
There is something that I'm missing? Is there anything else that should be
done after updating the metadata via Oracle sentences?
Montse,
I doubt that simply restarting Tomcat would rebuild the index. Go to "Administration" page by loging in as an administrator, and click the button "Rebuild Index". After the index rebuilding is done, logout and try to search again to see if it can be searched.
chopin
On Tuesday, October 7, 2014 8:55 AM, mmarco <mmarcosabate@anonymised.com> wrote:
updated properly.
directly
is
updated properly.
but
Using the admin > rebuild index option should synchronize the index with
the db.
On restart, it will synch also if you changed the last update date in the
db I think.
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
