I'm trying to configuration geonetwork in mysql database, I change the config.xml according to the manual
when I start the server, it has error about the "com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Specified key was too long; max key length is 767 bytes",it seems that the index length has too long, so what can I do to solve this problem?
The username column in the Users table is too long.
In web/geonetwork/WEB-INF/classes/setup/sql/create/create-db-mysql.sql
change the username column to varchar(20) instead of varchar(255). Then it
should work just fine.
Remember to drop the existing the tables before you start GeoNetwork again.
Get 100% visibility into Java/.NET code with AppDynamics Lite
It's a free troubleshooting tool designed for production
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes. http://p.sf.net/sfu/appdyn_d2d_ap2
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-users
