[GeoNetwork-users] Thesaurus / controlled vocabulary
Hi
I would like to create a Thesaurus or/and a controlled vocabulary.
Unfortunately i cannot manage to do that..
1) Is there a way where you can specify the words which may be entered in a metadata field?
2) Give (Thesaurus) suggestions for a specific field?
3) or change the values in the dropdown (suggestion) boxes?
I also tried to create an Thesaurus with the program ThManager but it somehow doesn't quite work as suspected.
Anyone done this before?
Any experiences with the geonetwork Thesaurus creation?
Thanks in advance,
Paul
p.s. usint version Geonetwork 2.6.0-1
Neu: GMX De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
Jetzt De-Mail-Adresse reservieren: http://portal.gmx.net/de/go/demail
Here is an example to create SKOS thesaurus using Talend Open Studio
http://www.talendforge.org/wiki/doku.php?id=sdi:howto:skosthesaurus
HTH
Francois
2010/10/4 Paul-s <paul-s@anonymised.com>:
Hi
Thanks in advance,
Paul
Virtualization is moving to the mainstream and overtaking non-virtualized
environment for deploying applications. Does it make network security
easier or more difficult to achieve? Read this whitepaper to separate the
two and get a better understanding.
http://p.sf.net/sfu/hp-phase2-d2d
GeoNetwork-users mailing list
