[GeoNetwork-users] Trouble setting up Geonetwork3 with postgresql/postgis
Hi All,
I have successfully compiled Geonetwork3 from source and had it running
with the default h2 database configuration. I am now trying to get it to
work with postgis/postgresql.
I've seen the thread here:
http://osgeo-org.1560.x6.nabble.com/How-to-use-PostGIS-spatial-index-in-3-0-0-Urgent-td5208696.html
and have the made the following changes:
1) edit config-db/jdbc.properties to point at my database (and also to
include jdbc.port)
2) edit config-node/srv.xml to load
config-db/postgis-alternate-datasource.xml (I got the same errors trying to
import jndi.postgres-postgis.xml)
I've also checked that I can connect to the remote postgresql database from
psql at the command line.
I wasn't clear if I also needed to edit config-db/postgres.xml as this
doesn't seem to be being imported in srv.xml.
When I try and start Geonetwork3 using mvn jetty:run it fails to start,
with the following errors:
2015-06-10 10:56:49,691 WARN
[org.springframework.security.config.http.FilterInvocationSecurityMetadataSourceParser]
- Duplicate URL defined: /metadata/.*. The original attribute values will
be overwritten
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'entityManagerFactory' defined in URL
[jar:file:/home/ubuntu/.m2/repository/org/geonetwork-opensource/domain/3.1.0-SNAPSHOT/domain-3.1.0-SNAPSHOT.jar!/config-spring-geonetwork.xml]:
Cannot resolve reference to bean 'jdbcDataSource' while setting bean
property 'dataSource'; nested exception is
org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean
named 'jdbcDataSource' is defined
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:329)
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1417)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1158)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:458)
at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:296)
at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223)
at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:293)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194)
at
org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1117)
at
org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:922)
at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:479)
at
jeeves.config.springutil.JeevesContextLoaderListener.contextInitialized(JeevesContextLoaderListener.java:56)
at
org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:775)
at
org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:424)
at
org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:767)
at
org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:249)
at
org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1250)
at
org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:710)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:492)
at
org.mortbay.jetty.plugin.JettyWebAppContext.doStart(JettyWebAppContext.java:293)
at
org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64)
at
org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229)
at
org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:172)
at
at
at
at
org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:95)
at org.eclipse.jetty.server.Server.doStart(Server.java:280)
at org.mortbay.jetty.plugin.JettyServer.doStart(JettyServer.java:65)
at
at
org.mortbay.jetty.plugin.AbstractJettyMojo.startJetty(AbstractJettyMojo.java:520)
at
org.mortbay.jetty.plugin.AbstractJettyMojo.execute(AbstractJettyMojo.java:365)
at org.mortbay.jetty.plugin.JettyRunMojo.execute(JettyRunMojo.java:523)
at
org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101)
at
org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209)
at
org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at
org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at
org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84)
at
org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
at
org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
at
org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at
org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at
org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at
org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.springframework.beans.factory.NoSuchBeanDefinitionException:
No bean named 'jdbcDataSource' is defined
at
org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeanDefinition(DefaultListableBeanFactory.java:570)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getMergedLocalBeanDefinition(AbstractBeanFactory.java:1114)
at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:279)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:198)
at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:270)
at
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323)
... 55 more
2015-06-10 10:56:52,941 FATAL [jeeves.engine] - Raised exception during init
2015-06-10 10:56:52,941 FATAL [jeeves.engine] - Exception :
2015-06-10 10:56:52,941 FATAL [jeeves.engine] - Message : Error
creating bean with name 'entityManagerFactory' defined in URL
2015-06-10 10:56:52,942 FATAL [jeeves.engine] - Stack :
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 55 more
2015-06-10 10:56:52.943:WARN:oejw.WebAppContext:Failed startup of context
o.m.j.p.JettyWebAppContext{/geonetwork,[file:/home/ubuntu/virtualenvs/geonetwork3_build/geonetwork/web/src/main/webapp/,
file:/home/ubuntu/virtualenvs/geonetwork3_build/geonetwork/web-ui/src/main/resources/,
file:/home/ubuntu/virtualenvs/geonetwork3_build/geonetwork/web/target/webapp/]},[file:/home/ubuntu/virtualenvs/geonetwork3_build/geonetwork/web/src/main/webapp/,
java.lang.RuntimeException: Exception raised
at jeeves.server.JeevesEngine.handleStartupError(JeevesEngine.java:211)
at
jeeves.config.springutil.JeevesContextLoaderListener.contextInitialized(JeevesContextLoaderListener.java:90)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
2015-06-10 10:56:52.953:INFO:oejs.AbstractConnector:Started
SocketConnector@anonymised.com:8080
2015-06-10 10:56:53.049:INFO:oejus.SslContextFactory:Enabled Protocols
[SSLv2Hello, TLSv1, TLSv1.1, TLSv1.2] of [SSLv2Hello, SSLv3, TLSv1,
TLSv1.1, TLSv1.2]
2015-06-10 10:56:53.063:INFO:oejs.AbstractConnector:Started
SslSocketConnector@anonymised.com:8443
[INFO] Started Jetty Server
Even though it ends with "Started Jetty Server" my application is
definitely not available.
Can anyone give me some pointers?
Thanks
Jo
*Jo Cook*
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18
7RL, UK
t:+44 7930 524 155
iShare - Data integration and publishing platform
<http://www.isharemaps.com/&gt;
Company registration no. 5410695. Registered in England and Wales.
Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
864201149.
Just use postgres.xml file if you're ok to have your spatial index in a
.shp, and a postgres database.
If you want your spatial index in postgis, refer to
http://osgeo-org.1560.x6.nabble.com/How-to-use-PostGIS-spatial-index-in-3-0-0-Urgent-td5208696.html#a5208977
On Wed, Jun 10, 2015 at 1:59 PM, Jo Cook <jocook@anonymised.com> wrote:
Hi All,
include jdbc.port)
be overwritten
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 55 more
init
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 55 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
TLSv1.1, TLSv1.2]
Thanks
Jo
*Jo Cook*
7RL, UK
t:+44 7930 524 155
864201149.
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Florent Gravin
Camptocamp - Chambéry
0479444492
Hi Florent,
Thanks for the response- I do want to use postgis for my spatial index, and
I followed that thread, but it's not very clear which datasource I should
be importing in srv.xml in that case. Can you clarify? Is it
postgis-alternate-datasource.xml or postgres.xml with the edits? Or do I
need to edit postgres.xml in both cases?
Thanks again
Jo
On Wed, Jun 10, 2015 at 2:22 PM, Florent Gravin <
florent.gravin@anonymised.com> wrote:
wrote:
Hi All,
include jdbc.port)
to
from
be overwritten
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
... 55 more
init
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
... 55 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
TLSv1.1, TLSv1.2]
Thanks
Jo
*Jo Cook*
7RL, UK
t:+44 7930 524 155
864201149.
Florent Gravin
0479444492
*Jo Cook*
7RL, UK
t:+44 7930 524 155
864201149.
It seems he kept the import of postgres.xml
and then he modified the postgres.xml with
<import resource="defaultJdbcDataSource.xml" />
    <import resource="postgis-alternate-datasource.xml" />
    <bean id="jpaVendorAdapterDatabaseParam" class="java.lang.String">
        <constructor-arg value="POSTGRESQL"/>
    </bean>
    <bean id="jdbcDriverClassName" class="java.lang.String">
        <constructor-arg value="org.postgis.DriverWrapper"/>
    </bean>
    <bean id="jdbcURL" class="java.lang.String">
        <constructor-arg
value="jdbc:postgresql_postGIS://${jdbc.host}:5432/${jdbc.database}"/>
On Wed, Jun 10, 2015 at 3:28 PM, Jo Cook <jocook@anonymised.com> wrote:
Hi Florent,
and I followed that thread, but it's not very clear which datasource I
should be importing in srv.xml in that case. Can you clarify? Is it
Thanks again
Jo
wrote:
Hi All,
include jdbc.port)
to
from
be overwritten
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
... 55 more
init
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
... 55 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
TLSv1.1, TLSv1.2]
Thanks
Jo
*Jo Cook*
KT18
7RL, UK
t:+44 7930 524 155
864201149.
Florent Gravin
0479444492
*Jo Cook*
7RL, UK
t:+44 7930 524 155
864201149.
Florent Gravin
0479444492
Hi Jo,
I may not have made myself clear. To recap:
Step 1: In srv.xml, import postgres.xml and comment out all the others.
Step 2: Modify jdbc.properties based on your username, password and port.
Step 3: Modify three places in postgres.xml.
<import resource="defaultJdbcDataSource.xml" /> Please don't remove
this line. You still need it
*<import resource="postgis-alternate-datasource.xml" /> 1:Very
important!!!import postgis-alternate-datasource.xml*
    </bean>
        *<constructor-arg value="org.postgis.DriverWrapper"/> 2: change
jdbc driver to Postgis*
    </bean>
        *<constructor-arg
value="jdbc:postgresql_postGIS://${jdbc.host}:5432/${jdbc.database}"/> 3:
change link to postgresql_postGIS *
    </bean>
Hope it is clear now. If you still have any problem, just send me your
modified files and I will take a look.
Cody
Geospatial discovery and cyberinfrastructure
View this message in context: http://osgeo-org.1560.x6.nabble.com/Trouble-setting-up-Geonetwork3-with-postgresql-postgis-tp5210160p5210199.html
One more thing, don't forget to create a postgis extension in Postgresql.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Trouble-setting-up-Geonetwork3-with-postgresql-postgis-tp5210160p5210200.html
Thanks for clarifying, that has worked fine and Geonetwork3 is now working
with PostGIS.
Jo
*Jo Cook*
7RL, UK
t:+44 7930 524 155
864201149.
