[GeoNetwork-users] Update the Bing key to use your own
Dear all,
when you install GeoNetwork remember to change the Bing key value to your
own value (see https://msdn.microsoft.com/en-us/library/ff428642.aspx). The
default GeoNetwork key is now blocked due to too many requests, so this
explains why you may have blank maps now.
Thanks.
Francois
Thanks Francois, Where do we put the key once we have our own value?
Is there a specific file that needs to be changed?
Thanks
Kevin
View this message in context: http://osgeo-org.1560.x6.nabble.com/Update-the-Bing-key-to-use-your-own-tp5324320p5324524.html
Hi Kevin
The bing key is set in the admin console \ settings \ map \ bing map key.
To be clear which maps were blank? I am finding that the osm tiles are not
appearing in the metadata record map (region.getmap.png) but unsure if this
is related. Could someone confirm?
I have set the bing key but it didn't seem to change anything even after a
restart.
Thanks
Kevin
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Luke Bassett*
* <lukembassett@anonymised.com>*Melbourne Australia
In the viewer main map, if you choose Bing as background, it is white cause
the tiles are not loaded cause of depecrated key.
> Thanks
> Kevin
> geonetwork-users List Signup and Options
> projects/geonetwork
*Luke Bassett*
projects/geonetwork
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
0479444492
Hi Luke
Sounds like a cache or cookies, try deleting your cache and cookie history
on your web browser.
Hope that helps
Kevin
View this message in context: http://osgeo-org.1560.x6.nabble.com/Update-the-Bing-key-to-use-your-own-tp5324320p5324875.html
