[GeoNetwork-users] Upgrade crashed
Hi guys,
I tried to upgrade from a GN3.6 to 3.10.2. It seems that there are Database changes as applying the update resulted in 0 records from 360. So I tried rolling back the apllication, but now I get an error like in the attached Textfile, that tells me something is wrong with may database.....
Is there any way to fix this without restoring the database to its former glory. I did not order a database backup because I tried it on another local test system and it worked smooth as a charm.
In terms of system specs it is nothing unusual: Tomcat 8, useage of postgresDB, external Data Directory, Ubuntu 18.04.4 LTS Server.
I really need your help guys. Thank you so much.
Cheers Andreas
(attachments)
GN_error (8.38 KB)
Hello Andreas
I recently updated from 3.6.0 to 3.10.1 as well and it worked.
Did you save & restore or even better repeat all your configurations after the deployment of the updated GeoNetwork?
For me I only had little configurations done, so it was
  - webapps/geonetwork/WEB-INF/config-node/srv.xml
  - webapps/geonetwork/WEB-INF/config-db/jdbc.properties
...where your Database connection is configured.
Also some translation files, images, ... but those should not have anything to do with your problem.
Mit freundlichen Grüßen
Sven van Crombrugge
Sachgebiet 3.3 - Geoinformationssysteme, E-Government -
- Zentrale -
Von der Heydt 22 . 66115 Saarbrücken
Tel.: +49 (0) 681 9712-303 · Fax: +49 (0) 681 9712-200
S.vanCrombrugge@...1788... · www.lvgl.saarland.de
________________________________________________________________________________________________
Hinweis zum Datenschutz
Informationen über die Verarbeitung Ihrer personenbezogenen Daten gemäß Artikel 13 und Artikel 14 der
Verordnung (EU) 2016/679 (DSGVO) sind elektronisch auf unserer Internetseite abrufbar:
https://www.saarland.de/vermessung_geoinformation_landentwicklung.htm
unter der Rubrik: Hinweise zum Datenschutz
Von: Andreas Böhme <andreas.boehme@...181...>
Gesendet: Dienstag, 28. April 2020 16:43
An: geonetwork-users@lists.sourceforge.net
Betreff: [GeoNetwork-users] Upgrade crashed
Hi guys,
Cheers Andreas
Hi Sven,
thx for your reply. I did everything "as usual". Like you said, it is not much to change, I did the same changes as you mentioned. Usually it worked well so far and I never experienced any problems.
But there is a first time for everything I guess.
I redeployed my old version but it didn't work due to the database. Now I get this errors. I could also go the fast forward way to the newest version, but then why is my Metadata not shown. Our DB-Admin gave me the following log entries that occurred when upgrading to 3.10.2:
2020-04-28 15:32:30 CEST [15047] geonetwork@anonymised.com ERROR: constraint "uk_fwi9l3n3vcxonf7c3x1ntdivx" of relation "links" does not exist
2020-04-28 15:32:30 CEST [15047] geonetwork@anonymised.com STATEMENT: alter table Links drop constraint UK_fwi9l3n3vcxonf7c3x1ntdivx
2020-04-28 15:32:30 CEST [15047] geonetwork@anonymised.com ERROR: constraint "uk_itccbjhvevxbh1g4axknj8n24" of relation "metadatadraft" does not exist
2020-04-28 15:32:30 CEST [15047] geonetwork@anonymised.com STATEMENT: alter table MetadataDraft drop constraint UK_itccbjhvevxbh1g4axknj8n24
2020-04-28 15:32:30 CEST [15047] geonetwork@anonymised.com ERROR: constraint "uk_fuc1tr6xyyrbjrxg0feavofb2" of relation "metadatadraft" does not exist
2020-04-28 15:32:30 CEST [15047] geonetwork@anonymised.com STATEMENT: alter table MetadataDraft drop constraint UK_fuc1tr6xyyrbjrxg0feavofb2
Any suggestions? Anyone ?
Thx
Andreas
Am 28.04.2020 um 17:00 schrieb van Crombrugge, Sven (LVGL):
Hello Andreas
Sven van Crombrugge
- Zentrale -
S.vanCrombrugge@anonymised.com · www.lvgl.saarland.de
Von: Andreas Böhme <andreas.boehme@anonymised.com>
Hi guys,
Cheers Andreas
Andreas Böhme
Techniker/Technician
Landschaftsökologie/Computational Landscape Ecology
Helmholtz-Zentrum für Umweltforschung GmbH - UFZ
Helmholtz Centre for Environmental Research GmbH - UFZ
Permoserstraße 15, 04318 Leipzig, Germany
Phone +49 341 235 1058
andreas.boehme@anonymised.com, www.ufz.de
Sitz der Gesellschaft/Registered Office: Leipzig
Registergericht/Registration Office: Amtsgericht Leipzig
Handelsregister Nr./Trade Register Nr.: B 4703
Vorsitzender des Aufsichtsrats/Chairman of the Supervisory Board: N.N.
Wissenschaftlicher Geschäftsführer/Scientific Managing Director:
Prof. Dr. Georg Teutsch
Administrative Geschäftsführerin/Administrative Managing Director:
Dr. Sabine König
Vermeiden Sie unnötige Ausdrucke./Think before printing.
Informationen aus der Wissenschaft (z.B. Veranstaltungshinweise, Projektangaben, Publikationen,
Bücher)
Hi Andreas
I would check the migrations since 3.6:
https://github.com/geonetwork/core-geonetwork/tree/3.10.x/web/src/main/webapp/WEB-INF/classes/setup/sql/migrate
v370
v381
v382
v383
v390
v310
v3101
v3102
And try to apply them manually, some of them will fail if already applied,
but hope can fix the missing stuff.
Jose García
On Tue, Apr 28, 2020 at 5:08 PM Andreas Böhme <andreas.boehme@anonymised.com.> wrote:
Hi Sven,
does not exist
Thx
Andreas
> Hello Andreas
> Sven van Crombrugge
> - Zentrale -
> Hi guys,
database.....
> Cheers Andreas
Andreas Böhme
Dr. Sabine König
Bücher)
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
Hi Jose,
thx for your answer,. Could you explain a little bit more in detail please. So just firing the changed SQL-Statements for example or replacing them in my files on the server? It is not only SQL that has changed, am I right? Would you go backward or forward to the newest version? I feel quite lost right now....
Am 28.04.2020 um 17:13 schrieb Jose Garcia:
Hi Andreas
I would check the migrations since 3.6: https://github.com/geonetwork/core-geonetwork/tree/3.10.x/web/src/main/webapp/WEB-INF/classes/setup/sql/migrate
v370
v381
v382
v383
v390
v310
v3101
v3102
And try to apply them manually, some of them will fail if already applied, but hope can fix the missing stuff.
Jose García
On Tue, Apr 28, 2020 at 5:08 PM Andreas Böhme <andreas.boehme@anonymised.com... <mailto:andreas.boehme@anonymised.com>> wrote:
    Hi Sven,
    Usually it
    database. Now
    me the
    does not exist
    STATEMENT: alter
    STATEMENT: alter
    STATEMENT: alter
    Thx
    Andreas
    > Hello Andreas
    > I recently updated from 3.6.0 to 3.10.1 as well and it worked.
    > Did you save & restore or even better repeat all your
    > For me I only had little configurations done, so it was
    > - webapps/geonetwork/WEB-INF/config-node/srv.xml
    > - webapps/geonetwork/WEB-INF/config-db/jdbc.properties
    > ...where your Database connection is configured.
    > Also some translation files, images, ... but those should not
    > Mit freundlichen Grüßen
    > Sven van Crombrugge
    > Sachgebiet 3.3 - Geoinformationssysteme, E-Government -
    > - Zentrale -
    > Von der Heydt 22 . 66115 Saarbrücken
    > Tel.: +49 (0) 681 9712-303 · Fax: +49 (0) 681 9712-200
    > S.vanCrombrugge@anonymised.com
    <mailto:S.vanCrombrugge@anonymised.com> · www.lvgl.saarland.de
    <http://www.lvgl.saarland.de>
    > Hinweis zum Datenschutz
    > Informationen über die Verarbeitung Ihrer personenbezogenen
    > Verordnung (EU) 2016/679 (DSGVO) sind elektronisch auf unserer
    > unter der Rubrik: Hinweise zum Datenschutz
    > -----Ursprüngliche Nachricht-----
    > Von: Andreas Böhme <andreas.boehme@anonymised.com
    > Gesendet: Dienstag, 28. April 2020 16:43
    > An: geonetwork-users@lists.sourceforge.net
    <mailto:geonetwork-users@lists.sourceforge.net>
    > Betreff: [GeoNetwork-users] Upgrade crashed
    > Hi guys,
    > I tried to upgrade from a GN3.6 to 3.10.2. It seems that there
    from 360.
    > So I tried rolling back the apllication, but now I get an error
    > Is there any way to fix this without restoring the database to
    > In terms of system specs it is nothing unusual: Tomcat 8, useage
    > I really need your help guys. Thank you so much.
    > Cheers Andreas
    Andreas Böhme
    andreas.boehme@anonymised.com <mailto:andreas.boehme@anonymised.com>, www.ufz.de
    <http://www.ufz.de>
    Dr. Sabine König
    Bücher)
    <mailto:GeoNetwork-users@lists.sourceforge.net>
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664 <tel:+31318416664>
Please consider the environment before printing this email.
Andreas Böhme
Dr. Sabine König
Bücher)
Hi Andreas,
We had to reindex our records in order to see them after updating from
3.6 to 3.10.x.
Did you run a reindex?
César Martínez
On Tue, 28 Apr 2020 at 17:32, Andreas Böhme <andreas.boehme@anonymised.com> wrote:
Hi Jose,
> Hi Andreas
> v370
> v381
> v382
> v383
> v390
> v310
> v3101
> v3102
> Regards,
> Jose García
> On Tue, Apr 28, 2020 at 5:08 PM Andreas Böhme <andreas.boehme@anonymised.com81...
> Hi Sven,
> Usually it
> database. Now
> me the
> does not exist
> STATEMENT: alter
> STATEMENT: alter
> STATEMENT: alter
> Thx
> Andreas
> > Hello Andreas
> > Sven van Crombrugge
> > - Zentrale -
> > Hi guys,
> from 360.
> > Cheers Andreas
> Andreas Böhme
> <http://www.ufz.de>
> Dr. Sabine König
> Bücher)
> Jose García
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
Andreas Böhme
Dr. Sabine König
Bücher)
   César Martínez Izquierdo
   GIS developer
   SCOLAB: http://www.scolab.es
Bingo, I just went forward again deploying the 3.10.2 version and did a reindex and all my results are there again.
Thank you so much everybody for your help and suggestions. This list is awesome :slight_smile:
Cheers and, for sure, here u soon :wink:
Andreas
Am 28.04.2020 um 18:14 schrieb César Martínez Izquierdo:
Hi Andreas,
3.6 to 3.10.x.
César Martínez
On Tue, 28 Apr 2020 at 17:32, Andreas Böhme <andreas.boehme@anonymised.com.> wrote:
Hi Jose,
Hi Andreas
v370
v381
v382
v383
v390
v310
v3101
v3102
Jose García
     Hi Sven,
     Usually it
     database. Now
     me the
     does not exist
     STATEMENT: alter
     STATEMENT: alter
     STATEMENT: alter
     Thx
     Andreas
     > Hello Andreas
     > - Zentrale -
     > Hi guys,
     from 360.
     > Cheers Andreas
     Andreas Böhme
     <http://www.ufz.de>
     Dr. Sabine König
     Bücher)
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Andreas Böhme
Dr. Sabine König
Bücher)
Andreas Böhme
Dr. Sabine König
Bücher)
