Hi List
I have this question. Its possible upload a file with size of 60GB on
geonetwork?
Thanks..
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upload-File-60-GB-tp5236291.html
Hello,
Due to http limitation, you will not be able to upload file larger than
1Go. So you will need to tranfer this file to server with something like
ftp, ssh or rsync and then load this file from server file system.
What kind of files do you have ?
Julien
2015-11-14 0:34 GMT+01:00 cbeltran <cbeltran@anonymised.com>:
Hi List
geonetwork?
Thanks..
GeoNetwork-users mailing list
hi
thanks, I configure on file config.xml, variable MaxUploadSize to 70000MB,
but not works. The file that I tried upload is a compressed zip.
I uploaded the file with rsync on folder the metadata id, but on geonetwork
appears error not recognize the file upload.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upload-File-60-GB-tp5236291p5237219.html
What kind of file are you using ? What is the content of your zip file ?
Julien
2015-11-18 17:05 GMT+01:00 cbeltran <cbeltran@anonymised.com>:
hi
Hi
The content Is File Geodatabase.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upload-File-60-GB-tp5236291p5237420.html
You can only import *metadata* on geonetwork but you're trying to import
*data*
2015-11-19 14:04 GMT+01:00 cbeltran <cbeltran@anonymised.com>:
Hi
Hi Julien,
That's wrong. You can actually upload data with a metadata record. And the maximum file size is indeed set in config.xml.
Cbeltran I suggest you look at the logfile to see what caused the failure. 60GB is pretty big. You could upload a small zip with an identical name and then manually replace that small file with the 60GB version manually in the upload folder.
Jeroen
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer, MapServer, PostGIS and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
Tel: +31 (0)6 81286572
http://geocat.net
Op 19 nov. 2015 om 14:17 heeft Julien Acroute <julien.acroute@anonymised.com> het volgende geschreven:
*data*
Hi
Hi Jeroen
Thanks for tour reply, I tried upload a small zip with an identical name.
Then I upload with Rsync the file 60GB in the folder and replace for a small
file. So I did restart tomcat and I checked the metadata record.I had tried
download the file but appears error: Exception Strings with the number of GB
on KB, for example 60GB ---> 64568987 KB and I can't download this data.
Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upload-File-60-GB-tp5236291p5237525.html
Hi
Can you provide the log file, to check the exception?
Jose García
On Thu, Nov 19, 2015 at 10:57 PM, cbeltran <cbeltran@anonymised.com> wrote:
Hi Jeroen
small
GB
Thanks
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv>
<https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
This is the log:
2015-11-13 17:01:26,865 INFO [jeeves.request] - HTML Request (from
192.168.16.34) : /geonetwork/srv/eng/resources.get
2015-11-13 17:01:26,866 INFO [jeeves.service] - Dispatching : resources.get
2015-11-13 17:01:26,871 INFO [jeeves.webapp.resources.get] - File is :
/mnt/datosgn/data/metadata_data/00400-00499/466/private/PRODUCTO_1_-_BASE_DE_DATOS_GEODATABASE_DE_IMGENES.zip
2015-11-13 17:01:27,320 INFO [jeeves.service] - -> dispatching to output
for : resources.get
2015-11-13 17:01:27,321 INFO [jeeves.service] - -> dispatching to error
for : resources.get
2015-11-13 17:01:27,681 INFO [jeeves] - Overrides being applied to
configuration file: .*/WEB-INF/config-gui.xml
2015-11-13 17:01:27,682 INFO [jeeves] - Replacing attribute widget of node
client
2015-11-13 17:01:27,682 INFO [jeeves] - Replacing attribute url of node
client
2015-11-13 17:01:27,682 INFO [jeeves] - Replacing attribute parameters of
node client
2015-11-13 17:01:27,682 INFO [jeeves] - Replacing attribute createParameter
of node client
2015-11-13 17:01:27,683 INFO [jeeves] - Replacing attribute stateId of node
client
2015-11-13 17:01:27,692 INFO [jeeves.service] - -> transforming with
stylesheet : /opt/tomcat/webapps/geonetwork/xsl/error.xsl
2015-11-13 17:01:27,765 INFO [jeeves.service] - -> end error
transformation for : resources.get
2015-11-13 17:01:27,765 INFO [jeeves.service] - -> error ended for :
resources.get
2015-11-13 17:01:39,866 INFO [jeeves.request] -
2015-11-13 17:02:44,076 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:02:44,077 INFO [jeeves.service] - Dispatching : resources.get
2015-11-13 17:02:44,081 INFO [jeeves.webapp.resources.get] - File is :
2015-11-13 17:02:44,372 INFO [jeeves.service] - -> dispatching to output
for : resources.get
2015-11-13 17:02:44,373 INFO [jeeves.service] - -> dispatching to error
for : resources.get
2015-11-13 17:02:44,594 INFO [jeeves] - Overrides being applied to
2015-11-13 17:02:44,595 INFO [jeeves] - Replacing attribute widget of node
client
2015-11-13 17:02:44,595 INFO [jeeves] - Replacing attribute url of node
client
2015-11-13 17:02:44,595 INFO [jeeves] - Replacing attribute parameters of
node client
2015-11-13 17:02:44,595 INFO [jeeves] - Replacing attribute createParameter
of node client
2015-11-13 17:02:44,595 INFO [jeeves] - Replacing attribute stateId of node
client
2015-11-13 17:02:44,601 INFO [jeeves.service] - -> transforming with
2015-11-13 17:02:44,621 INFO [jeeves.service] - -> end error
2015-11-13 17:02:44,621 INFO [jeeves.service] - -> error ended for :
resources.get
2015-11-13 17:03:22,209 INFO [jeeves.request] -
2015-11-13 17:03:22,209 INFO [jeeves.request] - HTML Request (from
192.168.16.34) : /geonetwork/srv/spa/xml.schema.info
2015-11-13 17:03:22,211 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:03:22,233 INFO [jeeves.service] - -> dispatching to output
for : xml.schema.info
2015-11-13 17:03:22,233 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:03:22,234 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:03:22,234 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:03:24,497 INFO [jeeves.request] -
2015-11-13 17:03:24,497 INFO [jeeves.request] - HTML Request (from
192.168.16.34) : /geonetwork/srv/spa/edit
2015-11-13 17:03:24,498 INFO [jeeves.service] - Dispatching : edit
2015-11-13 17:03:24,695 INFO [jeeves.service] - -> dispatching to output
for : edit
2015-11-13 17:03:24,960 INFO [jeeves] - Overrides being applied to
2015-11-13 17:03:24,961 INFO [jeeves] - Replacing attribute widget of node
client
2015-11-13 17:03:24,961 INFO [jeeves] - Replacing attribute url of node
client
2015-11-13 17:03:24,961 INFO [jeeves] - Replacing attribute parameters of
node client
2015-11-13 17:03:24,961 INFO [jeeves] - Replacing attribute createParameter
of node client
2015-11-13 17:03:24,961 INFO [jeeves] - Replacing attribute stateId of node
client
2015-11-13 17:03:24,978 INFO [jeeves.service] - -> transforming with
stylesheet : /opt/tomcat/webapps/geonetwork/xsl/metadata/edit/edit.xsl
2015-11-13 17:03:26,097 INFO [jeeves.service] - -> end transformation
for : edit
2015-11-13 17:03:26,097 INFO [jeeves.service] - -> output ended for :
edit
2015-11-13 17:03:26,097 INFO [jeeves.service] - -> dispatch ended for :
edit
2015-11-13 17:03:26,497 INFO [jeeves.request] -
2015-11-13 17:03:26,497 INFO [jeeves.request] - HTML Request (from
192.168.16.34) : /geonetwork/srv/spa/xml.relation
2015-11-13 17:03:26,497 INFO [jeeves.service] - Dispatching : xml.relation
2015-11-13 17:03:26,663 INFO [jeeves.service] - -> dispatching to output
for : xml.relation
2015-11-13 17:03:27,376 INFO [jeeves] - Overrides being applied to
2015-11-13 17:03:27,376 INFO [jeeves] - Replacing attribute widget of node
client
2015-11-13 17:03:27,376 INFO [jeeves] - Replacing attribute url of node
client
2015-11-13 17:03:27,376 INFO [jeeves] - Replacing attribute parameters of
node client
2015-11-13 17:03:27,376 INFO [jeeves] - Replacing attribute createParameter
of node client
2015-11-13 17:03:27,377 INFO [jeeves] - Replacing attribute stateId of node
client
2015-11-13 17:03:27,377 INFO [jeeves.service] - -> transforming with
stylesheet : /opt/tomcat/webapps/geonetwork/xsl/metadata/relation.xsl
2015-11-13 17:03:27,395 INFO [jeeves.service] - -> end transformation
for : xml.relation
2015-11-13 17:03:27,395 INFO [jeeves.service] - -> output ended for :
xml.relation
2015-11-13 17:03:27,395 INFO [jeeves.service] - -> dispatch ended for :
xml.relation
2015-11-13 17:03:31,613 INFO [jeeves.request] -
2015-11-13 17:12:08,208 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:12:08,208 INFO [jeeves.service] - Dispatching : resources.get
2015-11-13 17:12:08,213 INFO [jeeves.webapp.resources.get] - File is :
/mnt/datosgn/data/metadata_data/00400-00499/466/private/PRODUCTO_1_-_BASE_DE_DATOS_GEODATABASE_DE_IMGENES.rar
2015-11-13 17:12:08,219 ERROR [jeeves.service] - Exception when executing
service
2015-11-13 17:12:08,219 ERROR [jeeves.service] - (C) Exc :
ResourceNotFoundEx : Resource not found
2015-11-13 17:12:08,220 INFO [jeeves.service] - -> dispatching to error
for : resources.get
2015-11-13 17:12:09,134 INFO [jeeves] - Overrides being applied to
2015-11-13 17:12:09,134 INFO [jeeves] - Replacing attribute widget of node
client
2015-11-13 17:12:09,134 INFO [jeeves] - Replacing attribute url of node
client
2015-11-13 17:12:09,135 INFO [jeeves] - Replacing attribute parameters of
node client
2015-11-13 17:12:09,136 INFO [jeeves] - Replacing attribute createParameter
of node client
2015-11-13 17:12:09,136 INFO [jeeves] - Replacing attribute stateId of node
client
2015-11-13 17:12:09,144 INFO [jeeves.service] - -> transforming with
2015-11-13 17:12:09,180 INFO [jeeves.service] - -> end error
2015-11-13 17:12:09,180 INFO [jeeves.service] - -> error ended for :
resources.get
2015-11-13 17:12:38,415 INFO [jeeves.request] -
2015-11-13 17:12:38,416 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:12:38,416 INFO [jeeves.service] - Dispatching : resources.get
2015-11-13 17:12:38,425 INFO [jeeves.webapp.resources.get] - File is :
2015-11-13 17:12:38,431 ERROR [jeeves.service] - Exception when executing
service
2015-11-13 17:12:38,431 ERROR [jeeves.service] - (C) Exc :
2015-11-13 17:12:38,432 INFO [jeeves.service] - -> dispatching to error
for : resources.get
2015-11-13 17:12:38,466 INFO [jeeves.service] - -> transforming with
2015-11-13 17:12:38,499 INFO [jeeves.service] - -> end error
2015-11-13 17:12:38,499 INFO [jeeves.service] - -> error ended for :
resources.get
2015-11-13 17:12:45,017 INFO [jeeves.request] -
2015-11-13 17:12:45,018 INFO [jeeves.request] -
2015-11-13 17:12:45,019 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:12:45,021 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:12:45,022 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:12:45,044 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:12:45,044 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:12:45,044 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:12:45,044 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:12:45,048 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:12:45,048 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:12:45,048 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:12:45,048 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:13:38,713 INFO [jeeves.request] -
2015-11-13 17:13:45,718 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:13:45,718 INFO [jeeves.service] - Dispatching : resources.get
2015-11-13 17:13:45,720 INFO [jeeves.webapp.resources.get] - File is :
2015-11-13 17:13:45,856 INFO [jeeves.service] - -> dispatching to output
for : resources.get
2015-11-13 17:13:45,856 INFO [jeeves.service] - -> dispatching to error
for : resources.get
2015-11-13 17:13:46,051 INFO [jeeves] - Overrides being applied to
2015-11-13 17:13:46,052 INFO [jeeves] - Replacing attribute widget of node
client
2015-11-13 17:13:46,052 INFO [jeeves] - Replacing attribute url of node
client
2015-11-13 17:13:46,052 INFO [jeeves] - Replacing attribute parameters of
node client
2015-11-13 17:13:46,052 INFO [jeeves] - Replacing attribute createParameter
of node client
2015-11-13 17:13:46,052 INFO [jeeves] - Replacing attribute stateId of node
client
2015-11-13 17:13:46,059 INFO [jeeves.service] - -> transforming with
2015-11-13 17:13:46,088 INFO [jeeves.service] - -> end error
2015-11-13 17:13:46,088 INFO [jeeves.service] - -> error ended for :
resources.get
2015-11-13 17:13:49,440 INFO [jeeves.request] -
2015-11-13 17:13:49,440 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:13:49,440 INFO [jeeves.service] - Dispatching : resources.get
2015-11-13 17:13:49,446 INFO [jeeves.webapp.resources.get] - File is :
2015-11-13 17:13:49,618 INFO [jeeves.service] - -> dispatching to output
for : resources.get
2015-11-13 17:13:49,619 INFO [jeeves.service] - -> output ended for :
resources.get
2015-11-13 17:13:49,620 INFO [jeeves.service] - -> dispatch ended for :
resources.get
2015-11-13 17:13:51,447 INFO [jeeves.request] -
2015-11-13 17:13:51,447 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:13:51,448 INFO [jeeves.request] -
2015-11-13 17:13:51,449 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:13:51,450 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:13:51,452 INFO [jeeves.request] -
2015-11-13 17:13:51,452 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:13:51,453 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:13:51,457 INFO [jeeves.request] -
2015-11-13 17:13:51,457 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:13:51,458 INFO [jeeves.service] - Dispatching :
xml.schema.info
xml.schema.info
2015-11-13 17:13:51,479 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:13:51,479 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:13:51,480 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:13:51,480 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:13:51,480 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:13:51,480 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
xml.schema.info
2015-11-13 17:13:51,481 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:13:51,485 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:13:51,486 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:13:51,486 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:13:51,486 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:13:51,488 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:13:51,488 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:13:51,489 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:13:51,489 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:13:51,933 INFO [jeeves.request] -
2015-11-13 17:15:49,582 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:15:49,582 INFO [jeeves.service] - Dispatching : resources.get
2015-11-13 17:15:49,587 INFO [jeeves.webapp.resources.get] - File is :
2015-11-13 17:15:49,768 INFO [jeeves.service] - -> dispatching to output
for : resources.get
2015-11-13 17:15:49,769 INFO [jeeves.service] - -> dispatching to error
for : resources.get
2015-11-13 17:15:50,025 INFO [jeeves] - Overrides being applied to
2015-11-13 17:15:50,026 INFO [jeeves] - Replacing attribute widget of node
client
2015-11-13 17:15:50,026 INFO [jeeves] - Replacing attribute url of node
client
2015-11-13 17:15:50,026 INFO [jeeves] - Replacing attribute parameters of
node client
2015-11-13 17:15:50,026 INFO [jeeves] - Replacing attribute createParameter
of node client
2015-11-13 17:15:50,026 INFO [jeeves] - Replacing attribute stateId of node
client
2015-11-13 17:15:50,034 INFO [jeeves.service] - -> transforming with
2015-11-13 17:15:50,066 INFO [jeeves.service] - -> end error
2015-11-13 17:15:50,066 INFO [jeeves.service] - -> error ended for :
resources.get
2015-11-13 17:17:19,510 INFO [jeeves.request] -
2015-11-13 17:17:19,510 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:17:19,511 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:17:19,516 INFO [jeeves.request] -
2015-11-13 17:17:19,516 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:17:19,519 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:17:19,519 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:17:19,519 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:17:19,519 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:17:19,521 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:17:19,523 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:17:19,523 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:17:19,523 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:17:19,523 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:29,856 INFO [jeeves.request] -
2015-11-13 17:18:29,856 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:29,857 INFO [jeeves.request] -
2015-11-13 17:18:29,857 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:29,857 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:18:29,859 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:18:29,865 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:29,866 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:29,866 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:29,866 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:29,866 INFO [jeeves.service] - -> dispatching to output
xml.schema.info
2015-11-13 17:18:29,867 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:29,867 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:30,149 INFO [jeeves.request] -
2015-11-13 17:18:30,149 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:30,151 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:18:30,153 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:30,153 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:30,153 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:30,153 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:33,756 INFO [jeeves.request] -
2015-11-13 17:18:33,756 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:33,757 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:18:33,759 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:33,759 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:33,762 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:33,762 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:33,762 INFO [jeeves.request] -
2015-11-13 17:18:33,762 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:33,768 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:18:33,770 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:33,770 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:33,770 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:33,770 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:34,254 INFO [jeeves.request] -
2015-11-13 17:18:34,254 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:34,255 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:18:34,261 INFO [jeeves.request] -
2015-11-13 17:18:34,261 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:34,262 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:18:34,265 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:34,265 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:34,265 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:34,265 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:34,266 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:34,267 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:34,271 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:34,271 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:34,450 INFO [jeeves.request] -
2015-11-13 17:18:34,450 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:34,457 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:18:34,459 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:34,459 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:34,460 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:34,460 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:34,650 INFO [jeeves.request] -
2015-11-13 17:18:34,650 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:34,651 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:18:34,652 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:18:34,654 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:34,654 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:34,655 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:34,655 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:34,655 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:34,655 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:34,656 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:34,656 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:36,154 INFO [jeeves.request] -
2015-11-13 17:18:36,155 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:36,157 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:18:36,159 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:36,159 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:36,160 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:36,160 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:36,162 INFO [jeeves.request] -
2015-11-13 17:18:36,162 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:36,164 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:18:36,166 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:36,166 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:36,166 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:36,166 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:36,276 INFO [jeeves.request] -
2015-11-13 17:18:36,276 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:36,278 INFO [jeeves.request] -
2015-11-13 17:18:36,278 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:36,279 INFO [jeeves.service] - Dispatching :
xml.schema.info
xml.schema.info
2015-11-13 17:18:36,303 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:36,303 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:36,303 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:36,303 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:36,306 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:36,306 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:36,307 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:36,307 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:18:37,058 INFO [jeeves.request] -
2015-11-13 17:18:37,058 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:18:37,059 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:18:37,067 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:18:37,068 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:18:37,068 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:18:37,068 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:19:01,158 INFO [jeeves.request] -
2015-11-13 17:19:01,158 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:19:01,160 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:19:01,168 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:19:01,168 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:19:01,168 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:19:01,168 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:19:01,257 INFO [jeeves.request] -
2015-11-13 17:19:01,257 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:19:01,259 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:19:01,261 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:19:01,261 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:19:01,261 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:19:01,261 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:19:03,457 INFO [jeeves.request] -
2015-11-13 17:19:03,457 INFO [jeeves.request] - HTML Request (from
192.168.16.34) : /geonetwork/srv/spa/q
2015-11-13 17:19:03,458 INFO [jeeves.service] - Dispatching : q
2015-11-13 17:19:03,458 INFO [jeeves.webapp.q] - Creating searchers
2015-11-13 17:19:03,490 INFO [jeeves.service] - -> dispatching to output
for : q
2015-11-13 17:19:03,490 INFO [jeeves.service] - -> writing xml for : q
2015-11-13 17:19:03,497 INFO [jeeves.service] - -> output ended for : q
2015-11-13 17:19:03,497 INFO [jeeves.service] - -> dispatch ended for : q
2015-11-13 17:19:03,555 INFO [jeeves.request] -
2015-11-13 17:19:03,555 INFO [jeeves.request] - HTML Request (from
192.168.16.34) : /geonetwork/srv/spa/xml.info
2015-11-13 17:19:03,555 INFO [jeeves.service] - Dispatching : xml.info
2015-11-13 17:19:03,558 INFO [jeeves.service] - -> dispatching to output
for : xml.info
2015-11-13 17:19:03,558 INFO [jeeves.service] - -> writing xml for :
xml.info
2015-11-13 17:19:03,559 INFO [jeeves.service] - -> output ended for :
xml.info
2015-11-13 17:19:03,559 INFO [jeeves.service] - -> dispatch ended for :
xml.info
2015-11-13 17:19:03,656 INFO [jeeves.request] -
2015-11-13 17:19:03,656 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:19:03,656 INFO [jeeves.service] - Dispatching : xml.info
2015-11-13 17:19:03,659 INFO [jeeves.service] - -> dispatching to output
for : xml.info
2015-11-13 17:19:03,659 INFO [jeeves.service] - -> writing xml for :
xml.info
2015-11-13 17:19:03,659 INFO [jeeves.service] - -> output ended for :
xml.info
2015-11-13 17:19:03,659 INFO [jeeves.service] - -> dispatch ended for :
xml.info
2015-11-13 17:19:03,756 INFO [jeeves.request] -
2015-11-13 17:19:03,756 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:19:03,756 INFO [jeeves.service] - Dispatching : xml.info
2015-11-13 17:19:03,759 INFO [jeeves.service] - -> dispatching to output
for : xml.info
2015-11-13 17:19:03,759 INFO [jeeves.service] - -> writing xml for :
xml.info
2015-11-13 17:19:03,759 INFO [jeeves.service] - -> output ended for :
xml.info
2015-11-13 17:19:03,759 INFO [jeeves.service] - -> dispatch ended for :
xml.info
2015-11-13 17:19:03,861 INFO [jeeves.request] -
2015-11-13 17:19:03,861 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:19:03,861 INFO [jeeves.service] - Dispatching : xml.info
2015-11-13 17:19:03,864 INFO [jeeves.service] - -> dispatching to output
for : xml.info
2015-11-13 17:19:03,864 INFO [jeeves.service] - -> writing xml for :
xml.info
2015-11-13 17:19:03,864 INFO [jeeves.service] - -> output ended for :
xml.info
2015-11-13 17:19:03,864 INFO [jeeves.service] - -> dispatch ended for :
xml.info
2015-11-13 17:19:03,956 INFO [jeeves.request] -
2015-11-13 17:19:03,956 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:19:03,956 INFO [jeeves.service] - Dispatching : xml.info
2015-11-13 17:19:03,959 INFO [jeeves.service] - -> dispatching to output
for : xml.info
2015-11-13 17:19:03,959 INFO [jeeves.service] - -> writing xml for :
xml.info
2015-11-13 17:19:03,959 INFO [jeeves.service] - -> output ended for :
xml.info
2015-11-13 17:19:03,959 INFO [jeeves.service] - -> dispatch ended for :
xml.info
2015-11-13 17:19:04,055 INFO [jeeves.request] -
2015-11-13 17:19:04,055 INFO [jeeves.request] - HTML Request (from
192.168.16.34) : /geonetwork/srv/spa/view
2015-11-13 17:19:04,055 INFO [jeeves.service] - Dispatching : view
2015-11-13 17:19:04,255 INFO [jeeves.service] - -> dispatching to output
for : view
2015-11-13 17:19:04,495 INFO [jeeves] - Overrides being applied to
2015-11-13 17:19:04,495 INFO [jeeves] - Replacing attribute widget of node
client
2015-11-13 17:19:04,495 INFO [jeeves] - Replacing attribute url of node
client
2015-11-13 17:19:04,495 INFO [jeeves] - Replacing attribute parameters of
node client
2015-11-13 17:19:04,495 INFO [jeeves] - Replacing attribute createParameter
of node client
2015-11-13 17:19:04,495 INFO [jeeves] - Replacing attribute stateId of node
client
2015-11-13 17:19:04,501 INFO [jeeves.service] - -> transforming with
stylesheet : /opt/tomcat/webapps/geonetwork/xsl/metadata/view/view.xsl
2015-11-13 17:19:04,749 INFO [jeeves.service] - -> end transformation
for : view
2015-11-13 17:19:04,749 INFO [jeeves.service] - -> output ended for :
view
2015-11-13 17:19:04,749 INFO [jeeves.service] - -> dispatch ended for :
view
2015-11-13 17:19:04,855 INFO [jeeves.request] -
2015-11-13 17:19:04,855 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:19:04,856 INFO [jeeves.service] - Dispatching : xml.relation
2015-11-13 17:19:04,972 INFO [jeeves.service] - -> dispatching to output
for : xml.relation
2015-11-13 17:19:05,203 INFO [jeeves] - Overrides being applied to
2015-11-13 17:19:05,203 INFO [jeeves] - Replacing attribute widget of node
client
2015-11-13 17:19:05,203 INFO [jeeves] - Replacing attribute url of node
client
2015-11-13 17:19:05,203 INFO [jeeves] - Replacing attribute parameters of
node client
2015-11-13 17:19:05,203 INFO [jeeves] - Replacing attribute createParameter
of node client
2015-11-13 17:19:05,204 INFO [jeeves] - Replacing attribute stateId of node
client
2015-11-13 17:19:05,204 INFO [jeeves.service] - -> transforming with
2015-11-13 17:19:05,240 INFO [jeeves.service] - -> end transformation
for : xml.relation
2015-11-13 17:19:05,240 INFO [jeeves.service] - -> output ended for :
xml.relation
2015-11-13 17:19:05,240 INFO [jeeves.service] - -> dispatch ended for :
xml.relation
2015-11-13 17:19:08,458 INFO [jeeves.request] -
2015-11-13 17:19:08,458 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:19:08,458 INFO [jeeves.service] - Dispatching : resources.get
2015-11-13 17:19:08,463 INFO [jeeves.webapp.resources.get] - File is :
2015-11-13 17:19:08,639 INFO [jeeves.service] - -> dispatching to output
for : resources.get
2015-11-13 17:19:08,644 INFO [jeeves.service] - -> dispatching to error
for : resources.get
2015-11-13 17:19:08,896 INFO [jeeves] - Overrides being applied to
2015-11-13 17:19:08,896 INFO [jeeves] - Replacing attribute widget of node
client
2015-11-13 17:19:08,896 INFO [jeeves] - Replacing attribute url of node
client
2015-11-13 17:19:08,896 INFO [jeeves] - Replacing attribute parameters of
node client
2015-11-13 17:19:08,896 INFO [jeeves] - Replacing attribute createParameter
of node client
2015-11-13 17:19:08,896 INFO [jeeves] - Replacing attribute stateId of node
client
2015-11-13 17:19:08,904 INFO [jeeves.service] - -> transforming with
2015-11-13 17:19:08,998 INFO [jeeves.service] - -> end error
2015-11-13 17:19:08,998 INFO [jeeves.service] - -> error ended for :
resources.get
2015-11-13 17:19:19,559 INFO [jeeves.request] -
2015-11-13 17:19:19,559 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:19:19,560 INFO [jeeves.service] - Dispatching : resources.get
2015-11-13 17:19:19,565 INFO [jeeves.webapp.resources.get] - File is :
2015-11-13 17:19:19,572 ERROR [jeeves.service] - Exception when executing
service
2015-11-13 17:19:19,572 ERROR [jeeves.service] - (C) Exc :
2015-11-13 17:19:19,573 INFO [jeeves.service] - -> dispatching to error
for : resources.get
2015-11-13 17:19:19,837 INFO [jeeves] - Overrides being applied to
2015-11-13 17:19:19,838 INFO [jeeves] - Replacing attribute widget of node
client
2015-11-13 17:19:19,838 INFO [jeeves] - Replacing attribute url of node
client
2015-11-13 17:19:19,838 INFO [jeeves] - Replacing attribute parameters of
node client
2015-11-13 17:19:19,838 INFO [jeeves] - Replacing attribute createParameter
of node client
2015-11-13 17:19:19,838 INFO [jeeves] - Replacing attribute stateId of node
client
2015-11-13 17:19:19,846 INFO [jeeves.service] - -> transforming with
2015-11-13 17:19:19,880 INFO [jeeves.service] - -> end error
2015-11-13 17:19:19,880 INFO [jeeves.service] - -> error ended for :
resources.get
2015-11-13 17:19:34,953 INFO [jeeves.request] -
2015-11-13 17:19:34,953 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:19:34,955 INFO [jeeves.service] - Dispatching :
xml.schema.info
2015-11-13 17:19:34,978 INFO [jeeves.service] - -> dispatching to output
2015-11-13 17:19:34,978 INFO [jeeves.service] - -> writing xml for :
xml.schema.info
2015-11-13 17:19:34,979 INFO [jeeves.service] - -> output ended for :
xml.schema.info
2015-11-13 17:19:34,979 INFO [jeeves.service] - -> dispatch ended for :
xml.schema.info
2015-11-13 17:19:35,753 INFO [jeeves.request] -
2015-11-13 17:19:35,753 INFO [jeeves.request] - HTML Request (from
2015-11-13 17:19:35,754 INFO [jeeves.service] - Dispatching : resources.get
2015-11-13 17:19:35,758 INFO [jeeves.webapp.resources.get] - File is :
2015-11-13 17:19:35,960 INFO [jeeves.service] - -> dispatching to output
for : resources.get
2015-11-13 17:19:35,961 INFO [jeeves.service] - -> dispatching to error
for : resources.get
2015-11-13 17:19:36,004 INFO [jeeves.service] - -> transforming with
2015-11-13 17:19:36,037 INFO [jeeves.service] - -> end error
2015-11-13 17:19:36,037 INFO [jeeves.service] - -> error ended for :
resources.get
2015-11-13 17:19:58,671 INFO [jeeves.request] -
2015-11-13 17:23:05,847 INFO [jeeves.request] - HTML Request (from
192.168.16.34) : /geonetwork/srv/spa/resource.upload.and.link
2015-11-13 17:23:05,899 INFO [jeeves.service] - Dispatching :
2015-11-13 17:23:05,907 INFO [jeeves.webapp.resource.upload.and.link] -
Source :
/opt/tomcat/webapps/geonetwork/./data/tmp/PRODUCTO_1_-_BASE_DE_DATOS_GEODATABASE_DE_IMGENES.zip
Destin :
2015-11-13 17:23:05,944 INFO [jeeves.webapp.resource.upload.and.link] -
UPLOADED:PRODUCTO_1_-_BASE_DE_DATOS_GEODATABASE_DE_IMGENES.zip,466,192.168.16.34,cbeltran
2015-11-13 17:23:06,402 INFO [jeeves.service] - -> dispatching to output
for : resource.upload.and.link
2015-11-13 17:23:06,534 INFO [jeeves] - Overrides being applied to
2015-11-13 17:23:06,534 INFO [jeeves] - Replacing attribute widget of node
client
2015-11-13 17:23:06,534 INFO [jeeves] - Replacing attribute url of node
client
2015-11-13 17:23:06,534 INFO [jeeves] - Replacing attribute parameters of
node client
2015-11-13 17:23:06,534 INFO [jeeves] - Replacing attribute createParameter
of node client
2015-11-13 17:23:06,534 INFO [jeeves] - Replacing attribute stateId of node
client
2015-11-13 17:23:06,534 INFO [jeeves.service] - -> transforming with
stylesheet : /opt/tomcat/webapps/geonetwork/xsl/admin-logo-add.xsl
2015-11-13 17:23:06,606 INFO [jeeves.service] - -> end transformation
2015-11-13 17:23:06,606 INFO [jeeves.service] - -> output ended for :
2015-11-13 17:23:06,606 INFO [jeeves.service] - -> dispatch ended for :
2015-11-13 17:23:06,744 INFO [jeeves.request] -
Thanks...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upload-File-60-GB-tp5236291p5238099.html
This is the error when I try to download the file.
<http://osgeo-org.1560.x6.nabble.com/file/n5238107/error60gb.png>
Thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upload-File-60-GB-tp5236291p5238107.html
