I was suggesting that you make a copy of jndi.xml to jndi-postgres-postgis.xml and update the file to meet your postgres requirements.
Alternatively, point to jndi.xml instead of jndi-postgres-postgis.xml. But you will still need to update the jndi.xml to meet your postgres requirements. There is a sample for postgres in the jndi.xml file
https://github.com/geonetwork/core-geonetwork/blob/master/web/src/main/webResources/WEB-INF/config-db/jndi.xml
I have created a PR to update the sample to point to jndi.xml so that this may help avoid future confusion.
https://github.com/geonetwork/core-geonetwork/pull/5543
Sent: March 27, 2021 9:58 AM
To: Ian Allen <ianwallen@anonymised.com>
Subject: Re: [GeoNetwork-users] Using PostgreSQL/PostGIS in 4.0.3 (re-send)
Hi Ian!
I have followed those instructions to the best of my ability.
The error message is very clear:
Caused by: java.io.FileNotFoundException: C:\Program Files\Apache Software Foundation\Tomcat 9.0\webapps\GeoNetwork-4.0.3-0\WEB-INF\config-node\..\config-db\jndi-postgres-postgis.xml (The system cannot find the file specified)
at java.io.FileInputStream.open0(Native Method)
at java.io.FileInputStream.open(FileInputStream.java:195)
at java.io.FileInputStream.<init>(FileInputStream.java:138)
at java.io.FileInputStream.<init>(FileInputStream.java:93)
at sun.net.www.protocol.file.FileURLConnection.connect(FileURLConnection.java:90)
at sun.net.www.protocol.file.FileURLConnection.getInputStream(FileURLConnection.java:188)
at org.springframework.core.io.UrlResource.getInputStream(UrlResource.java:173)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:333)
... 60 more
As all the other db dialects are represented in the config-db folder, it is fair to assume that there would be a jndi-postgres-postgis.xml as well. Indeed, the instructions for srv.xml are simply "Choose the database type to use." (by uncommenting - commenting the appropriate strings)
I also created a localhost xml file from the JNDI example, named and placed at C:\Program Files\Apache Software Foundation\Tomcat 9.0\conf\Catalina\localhost as instructed.
However, I am pretty sure that the missing file in config-db is the key to the solution.
Regards, Mats.E
Den lör 27 mars 2021 kl 13:07 skrev Ian Allen <ianwallen@anonymised.com<mailto:ianwallen@anonymised.com>>:
Mats,
I thought you were trying to get the base geonetwork working.
which would have used the following
<!--<import resource="../config-db/postgres.xml"/>-->
In this case you would configure the jdbc options that you originally mentioned.
I'm assuming you are talking about the following line.
<!--<import resource="../config-db/jndi-postgres-postgis.xml"/> -->
That is just an example. I believe it is assumed that you would modify the jdni.xml for your database.
you would also need to modify your application server.
https://geonetwork-opensource.org/manuals/trunk/en/install-guide/configuring-database.html#configuring-a-database-via-jndi
There are some example here
https://github.com/geonetwork/core-geonetwork/tree/master/web/src/main/webResources/WEB-INF/config-db/jndiExamples_tomcat
If you provide the error message that you are receiving, it may help solve the issue.
From: Mats Elfström <mats.elfstrom@anonymised.com<mailto:mats.elfstrom@anonymised.com0…>>
Sent: March 26, 2021 3:35 PM
To: Ian Allen <ianwallen@anonymised.com<mailto:ianwallen@anonymised.com>>
Hi Ian!
Thanks for hints.
However, despite numerous attempts, Geonetwork 4 fails to start when directed to PostgreSQL. I have tried also JNDI, but the file jndi-postgres-postgis.xml is missing from config.db
It is the only apparent error message I get.
Regards, Mats.E
Den fre 26 mars 2021 kl 13:45 skrev Ian Allen <ianwallen@anonymised.com<mailto:ianwallen@anonymised.com>>:
Mats,
As you are using postgres, The values will be supplied to the following file.
https://github.com/geonetwork/core-geonetwork/blob/master/web/src/main/webResources/WEB-INF/config-db/postgres.xml
More specifically - this line
<constructor-arg value="jdbc:postgresql://${jdbc.host}:${jdbc.port:5432}/${jdbc.database}?${jdbc.connectionProperties}"/>
So if the port is not specified then it will default to 5432
The GEONETWORK_DB_USERNAME of www-data is just the default username and password that is used for H2 database. You will have to modify these to suit your database.
The following will also need to be modified to indicate the database that you want to use.
https://github.com/geonetwork/core-geonetwork/blob/master/web/src/main/webResources/WEB-INF/config-node/srv.xml
If you know how to supply the ENV variables to your application then you could pass those without having to modify any files at all.
i.e. if the following env were available to the application then it would connect to a postgres database on localhost using port 5432 with ssl mode.
GEONETWORK_DB_TYPE=postgres
GEONETWORK_DB_HOST=localhost
GEONETWORK_DB_PORT=5432
GEONETWORK_DB_NAME=geonetwork
GEONETWORK_DB_CONNECTION_PROPERTIES=sslmode=require
GEONETWORK_DB_USERNAME=geonetwork
GEONETWORK_DB_PASSWORD=password
Sent: March 26, 2021 8:36 AM
To: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@anonymised.comurceforge.net> <geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>>
Subject: [GeoNetwork-users] Using PostgreSQL/PostGIS in 4.0.3 (re-send)
Trying to configure this I encountered this syntax for the jdbc.properties.
jdbc.username=#{systemEnvironment['GEONETWORK_DB_USERNAME']?:'www-data'}
jdbc.password=#{systemEnvironment['GEONETWORK_DB_PASSWORD']?:'www-data'}
jdbc.database=#{systemEnvironment['GEONETWORK_DB_NAME']?:'~/gn'}
jdbc.host=#{systemEnvironment['GEONETWORK_DB_HOST']?:'localhost'}
jdbc.port=#{systemEnvironment['GEONETWORK_DB_PORT']}
jdbc.connectionProperties=#{systemEnvironment['GEONETWORK_DB_CONNECTION_PROPERTIES']}
And I am confused. shall GEONETWORK_DB_PORT be substituted with 5432 and
GEONETWORK_DB_USERNAME with the username, what is www-data?
Anyway, it seems not to work.
Please advise. The manual simply says that the file shall be updated.
I have used PostgreSQL databases before, but have no live instance at the
moment.
Regards, Mats.E
*GisKraft*, Geodatakonsult
Mats Elfström, Marsvinsholms stationsväg 80, 271 93 Ystad, Sweden
tel: +46 70 595 39 35 / www.giskraft.se<http://www.giskraft.se>
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@anonymised.comforge.net>
[https://drive.google.com/uc?id=1sRHl_CnQrtHqnEvCnblOPhzklqxxeH5J&export=download]
GisKraft, Geodatakonsult
