I'm trying to get geoNetwork working with a Postgres 8.3 database, Windows XP SP3, GeoNetwork 2.2.
When I run the db setup in GAST, things go OK to 92% progress (Filling Table CategoriesDes), then I get a PSQL exception
'setObject(i,Null) is not supported. Instead use setNull(i,Type) or setObject(i,null,type)'.
I can close the alert dialog, and the setup progress window goes away, but when I try to create data, there are no templates in the template list.
I notice a posting on what appears to be the same problem from Mar. 13, 2008 (Felipe dos Santos Costa).
Any ideas for solution?
thanks
steve
Stephen M. Richard
Section Chief, Geoinformatics
Arizona Geological Survey
416 W. Congress St., #100
Tucson, Arizona, 85701
USA
phone: (520) 770-3500. FAX: (520) 770-3505
email: steve.richard@anonymised.com
Hi Richard,
Yes, this is a problem that sometimes happens on Windows XP. It is not related to Postgres. After this installation, all is fine, except that the sample metadata was not loaded. you can use GAST once more to import the sample metadata manually. You will have to point the GAST metadata import to the folder ../gast/setup/sample-data and after that you should be all set.
Ciao,
Jeroen
thanks
steve
Stephen M. Richard
USA
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
Best Open Source Mac Front-Ends 2024
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
