I would like to ask what is the upload maximum size for data (png,
shapefile, pdf, zip, etc) on metadata
Thank you very much.
Regards
View this message in context: http://osgeo-org.1560.x6.nabble.com/What-is-the-max-upload-size-on-Geonetwork-tp5189000.html
Hi
The max size is set to 100 Mb, you can change it in the file
WEB-INF/config.xml:
<maxUploadSize>100</maxUploadSize>
The change requires to restart GeoNetwork.
Jose GarcĂa
On Fri, Feb 20, 2015 at 9:23 PM, cbeltran <cbeltran@anonymised.com> wrote:
Regards
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=190641631&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net/> for
details. _________________________Jose GarcĂaGeoCat bvVeenderweg 136721 WD
BennekomThe Netherlandshttp://GeoCat.net/>*
On 02/23/15 08:11, Jose Garcia wrote:
Hi
WEB-INF/config.xml:
And you might also need to check the max POST size settings in your frontend reverse proxy if you use one.
Landry Breuil
Mouton a 5 pattes du CRAIG
