Alguien puede saber a que se debe este error, pues no he logrado ver en que
falla, pues se crean las tablas, pero al parecer hay problemas al insertar
algunos registros.
2016-02-12 10:47:29,610 WARN [geonetwork] - Database does not
contain any version information. Check that the database is a GeoNetwork
database with data. Migration step aborted.
2016-02-12 10:47:41,756 WARN [geonetwork.data.directory] - - Data
directory properties is not set. Use geonetwork.dir or geonetwork.dir
properties.
2016-02-12 10:47:41,757 WARN [geonetwork.data.directory] - - Data
directory provided could not be used. Using default location:
C:\geonetwork\web\geonetwork\WEB-INF\data
2016-02-12 10:47:41,840 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data data-db-
2016-02-12 10:47:43,283 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-eng-
2016-02-12 10:47:44,355 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-fre-
2016-02-12 10:47:45,492 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-ger-
2016-02-12 10:47:46,611 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-spa-
2016-02-12 10:47:47,806 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-cat-
2016-02-12 10:47:48,948 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-rus-
2016-02-12 10:47:49,995 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-por-
2016-02-12 10:47:51,032 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-chi-
2016-02-12 10:47:52,053 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-dut-
2016-02-12 10:47:53,060 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-nor-
2016-02-12 10:47:54,042 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-fin-
2016-02-12 10:47:55,112 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-ara-
2016-02-12 10:47:56,097 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-ita-
2016-02-12 10:47:57,104 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-tur-
2016-02-12 10:47:58,081 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-vie-
2016-02-12 10:47:59,113 WARN [geonetwork.database] - Executing SQL from:
WEB-INF\classes\setup\sql\data loc-pol-
2016-02-12 10:48:00,425 WARN [jeeves.apphand] - Cannot initialize Z39.50
repositories because the file JZKitConfig.xml.tem could not be found in the
classpath
2016-02-12 10:48:00,425 ERROR [jeeves.apphand] - Repositories file
builder FAILED - Z3950 server disabled and Z3950 client services (remote
search, harvesting) may not work.
2016-02-12 10:48:01,335 WARN [geonetwork.schemamanager] - Cannot resolve
http://www.w3.org/2001/03/xml.xsd: will append last component to current
path (not sure it will help though!)
2016-02-12 10:48:01,808 WARN [geonetwork.schemamanager] - WARNING:
gco:Record is a global element without a type - assuming a string
2016-02-12 10:48:02,044 WARN [geonetwork.schemamanager] - WARNING:
2016-02-12 10:48:02,056 WARN [geonetwork.schemamanager] - WARNING:
schema-substitutions.xml has wiped out XSD substitution list for
gml:CoordinateSystemAxis
2016-02-12 10:48:02,062 WARN [geonetwork.schemamanager] - WARNING:
gml:VerticalCS
2016-02-12 10:48:02,067 WARN [geonetwork.schemamanager] - WARNING:
2016-02-12 10:48:02,068 WARN [geonetwork.schemamanager] - WARNING:
gml:VerticalDatum
2016-02-12 10:48:05,604 WARN [geonetwork.settings] - Requested setting
with name: system/requestedLanguage/ignorechars but null value found. Check
the settings table.
2016-02-12 10:48:05,701 WARN [geonetwork.settings] - Requested setting
the settings table.
2016-02-12 10:48:05,716 WARN [geonetwork.settings] - Requested setting
the settings table.
2016-02-12 10:48:05,720 WARN [geonetwork.settings] - Requested setting
the settings table.
2016-02-12 10:48:05,724 WARN [geonetwork.settings] - Requested setting
the settings table.
2016-02-12 10:48:05,729 WARN [geonetwork.settings] - Requested setting
the settings table.
2016-02-12 10:48:12,714 WARN [geonetwork.svnmanager] - Recreating
subversion repository at
C:\geonetwork\web\geonetwork\WEB-INF\data\data\metadata_subversion as
previous repository was empty
2016-02-12 10:48:20,432* ERROR **[geonetwork.index] - An error occurred
while openning taxonomy readers/writers*
*org.apache.lucene.store.LockObtainFailedException: Lock obtain timed out:
NativeFSLock@anonymised.com:\geonetwork\web\geonetwork\WEB-INF\data\index\taxonomy\write.lock*
at org.apache.lucene.store.Lock.obtain(Lock.java:89)
at org.apache.lucene.index.IndexWriter.<init>(IndexWriter.java:724)
at
org.apache.lucene.facet.taxonomy.directory.DirectoryTaxonomyWriter.openIndexWriter(DirectoryTaxonomyWriter.java:265)
at
org.apache.lucene.facet.taxonomy.directory.DirectoryTaxonomyWriter.<init>(DirectoryTaxonomyWriter.java:192)
at
org.apache.lucene.facet.taxonomy.directory.DirectoryTaxonomyWriter.<init>(DirectoryTaxonomyWriter.java:315)
at
org.apache.lucene.facet.taxonomy.directory.DirectoryTaxonomyWriter.<init>(DirectoryTaxonomyWriter.java:332)
at
org.fao.geonet.kernel.search.index.TaxonomyIndexTracker.init(TaxonomyIndexTracker.java:46)
at
org.fao.geonet.kernel.search.index.TaxonomyIndexTracker.<init>(TaxonomyIndexTracker.java:40)
at
org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.lazyInit(LuceneIndexLanguageTracker.java:59)
at
org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.acquire(LuceneIndexLanguageTracker.java:157)
at
org.fao.geonet.kernel.search.SearchManager.getIndexReader(SearchManager.java:1398)
at
org.fao.geonet.kernel.search.SearchManager.getNewIndexReader(SearchManager.java:1402)
at
org.fao.geonet.kernel.search.SearchManager.getDocsChangeDate(SearchManager.java:1057)
at org.fao.geonet.kernel.DataManager.init(DataManager.java:239)
at org.fao.geonet.Geonetwork.start(Geonetwork.java:378)
at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:452)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:173)
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:82)
at javax.servlet.GenericServlet.init(GenericServlet.java:244)
at
org.eclipse.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:532)
at
org.eclipse.jetty.servlet.ServletHolder.doStart(ServletHolder.java:344)
at
org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64)
at
org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:791)
at
org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:265)
at
org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1242)
at
org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:717)
at
org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:494)
at
at
org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:39)
at
org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:186)
at
org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:494)
at
org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:141)
at
org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:145)
at
org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:56)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:615)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:540)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:403)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:337)
at
at
org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:121)
at
at
org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:555)
at
org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:230)
at
at
org.eclipse.jetty.util.component.AggregateLifeCycle.doStart(AggregateLifeCycle.java:81)
at
org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:58)
at
org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:96)
at org.eclipse.jetty.server.Server.doStart(Server.java:282)
at
at
org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1274)
at java.security.AccessController.doPrivileged(Native Method)
at
org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1197)
2016-02-12 10:48:20,435 ERROR [jeeves.engine] - Raised exception while
starting the application. Fix the error and restart.
2016-02-12 10:48:20,435 ERROR [jeeves.engine] - Handler :
2016-02-12 10:48:20,435 ERROR [jeeves.engine] - Exception :
java.lang.RuntimeException:
2016-02-12 10:48:20,435 ERROR [jeeves.engine] - Message :
2016-02-12 10:48:20,436 ERROR [jeeves.engine] - Stack :
at
org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.lazyInit(LuceneIndexLanguageTracker.java:68)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: org.apache.lucene.store.LockObtainFailedException: Lock obtain
timed out: NativeFSLock@anonymised.com
at
at
at
at
at
at
at
... 43 more
