GeoPackage raster layer error in GeoServer
Hi everybody,
I have a problem when trying to add layers from a geopackage with raster layer stored in it. I can successfully list the layer(s) in GeoServer, but when trying to publish it I get an error.
Here is the file I’m working with: https://gis.lfrz.gv.at/data/geoinspire_raster.gpkg (2,5MB)
Here is gdalinfo of the file:
gdalinfo geoinspire_raster.gpkg -oo TABLE=test
Driver: GPKG/GeoPackage
Files: geoinspire_raster.gpkg
Size is 22308, 11658
Coordinate System is:
PROJCRS["WGS 84 / UTM zone 32N",
    BASEGEOGCRS["WGS 84",
        ENSEMBLE["World Geodetic System 1984 ensemble",
            MEMBER["World Geodetic System 1984 (Transit)"],
            MEMBER["World Geodetic System 1984 (G730)"],
            MEMBER["World Geodetic System 1984 (G873)"],
            MEMBER["World Geodetic System 1984 (G1150)"],
            MEMBER["World Geodetic System 1984 (G1674)"],
            MEMBER["World Geodetic System 1984 (G1762)"],
            MEMBER["World Geodetic System 1984 (G2139)"],
            MEMBER["World Geodetic System 1984 (G2296)"],
            ELLIPSOID["WGS 84",6378137,298.257223563,
                LENGTHUNIT["metre",1]],
            ENSEMBLEACCURACY[2.0]],
        PRIMEM["Greenwich",0,
            ANGLEUNIT["degree",0.0174532925199433]],
        ID["EPSG",4326]],
    CONVERSION["UTM zone 32N",
        METHOD["Transverse Mercator",
            ID["EPSG",9807]],
        PARAMETER["Latitude of natural origin",0,
            ANGLEUNIT["degree",0.0174532925199433],
            ID["EPSG",8801]],
        PARAMETER["Longitude of natural origin",9,
            ID["EPSG",8802]],
        PARAMETER["Scale factor at natural origin",0.9996,
            SCALEUNIT["unity",1],
            ID["EPSG",8805]],
        PARAMETER["False easting",500000,
            LENGTHUNIT["metre",1],
            ID["EPSG",8806]],
        PARAMETER["False northing",0,
            ID["EPSG",8807]]],
    CS[Cartesian,2],
        AXIS["(E)",east,
            ORDER[1],
        AXIS["(N)",north,
            ORDER[2],
    USAGE[
        SCOPE["Navigation and medium accuracy spatial referencing."],
        AREA["Between 6┬░E and 12┬░E, northern hemisphere between equator and 84┬░N, onshore and offshore. Algeria. Austria. Cameroon. Denmark. Equatorial Guinea. France. Gabon. Germany. Italy. Libya. Liechtenstein. Monaco. Netherlands. Niger. Nigeria. Norway. Sao Tome and Principe. Svalbard. Sweden. Switzerland. Tunisia. Vatican City State."],
        BBOX[0,6,84,12]],
    ID["EPSG",32632]]
Data axis to CRS axis mapping: 1,2
Origin = (540120.000000000000000,5292900.000000000000000)
Pixel Size = (10.000000000000000,-10.000000000000000)
Metadata:
  IDENTIFIER=test
  ZOOM_LEVEL=7
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  540120.000, 5292900.000) (  9d32' 8.33"E, 47d47'17.56"N)
Lower Left  (  540120.000, 5176320.000) (  9d31'30.60"E, 46d44'21.22"N)
Upper Right (  763200.000, 5292900.000) ( 12d30'38.45"E, 47d44' 8.65"N)
Lower Right (  763200.000, 5176320.000) ( 12d26'31.80"E, 46d41'19.07"N)
Center      (  651660.000, 5234610.000) ( 11d 0'14.97"E, 47d14'50.79"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
  Mask Flags: PER_DATASET ALPHA
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
Band 4 Block=256x256 Type=Byte, ColorInterp=Alpha
Here is the error log:
java.lang.RuntimeException: Error occurred while building the resources for the configuration page
	at org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:405)
	at org.geoserver.web.data.layer.NewLayerPage$9.onClick(NewLayerPage.java:304)
	at org.geoserver.web.wicket.SimpleAjaxLink$1.onClick(SimpleAjaxLink.java:47)
	at org.apache.wicket.ajax.markup.html.AjaxLink$1.onEvent(AjaxLink.java:85)
	at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:154)
	at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:630)
	at org.apache.wicket.core.request.handler.ListenerRequestHandler.internalInvoke(ListenerRequestHandler.java:300)
	at org.apache.wicket.core.request.handler.ListenerRequestHandler.invoke(ListenerRequestHandler.java:274)
	at org.apache.wicket.core.request.handler.ListenerRequestHandler.invokeListener(ListenerRequestHandler.java:222)
	at org.apache.wicket.core.request.handler.ListenerRequestHandler.respond(ListenerRequestHandler.java:202)
	at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:910)
	at org.apache.wicket.request.RequestHandlerExecutor.execute(RequestHandlerExecutor.java:63)
	at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:294)
	at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:255)
	at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:277)
	at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:208)
	at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:137)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:529)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:623)
	at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:166)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:51)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1072)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:965)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:898)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:197)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:142)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:166)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
	at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:103)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:67)
	at org.geoserver.ows.HTTPHeadersCollector.doFilter(HTTPHeadersCollector.java:48)
	at org.geoserver.filters.HTTPMethodFilter.doFilter(HTTPMethodFilter.java:34)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:180)
	at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:87)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:39)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:352)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:67)
	at org.springframework.security.web.access.intercept.AuthorizationFilter.doFilter(AuthorizationFilter.java:100)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:71)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:88)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:361)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:126)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:120)
	at org.geoserver.security.filter.GeoServerPreAuthenticationFilter.doFilter(GeoServerPreAuthenticationFilter.java:70)
	at org.geoserver.security.filter.GeoServerRequestHeaderAuthenticationFilter.doFilter(GeoServerRequestHeaderAuthenticationFilter.java:59)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:168)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:117)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:80)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilterInternal(GeoServerSecurityContextPersistenceFilter.java:66)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:225)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:190)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:139)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:354)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:267)
	at org.geoserver.filters.SecurityHeadersFilter.doFilter(SecurityHeadersFilter.java:116)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:46)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:41)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:166)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:88)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:491)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:83)
	at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:643)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:72)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:344)
	at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:398)
	at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:63)
	at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:939)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1854)
	at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:52)
	at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:973)
	at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:491)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:63)
	at java.base/java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException: Cannot invoke "org.eclipse.imagen.ImageLayout.clone()" because "this.imageLayout" is null
	at org.geotools.coverage.grid.io.AbstractGridCoverage2DReader.getImageLayout(AbstractGridCoverage2DReader.java:1091)
	at org.geoserver.catalog.CoverageDimensionCustomizerReader.getImageLayout(CoverageDimensionCustomizerReader.java:451)
	at org.geoserver.catalog.SingleGridCoverage2DReader.getImageLayout(SingleGridCoverage2DReader.java:190)
	at org.geoserver.catalog.CatalogBuilder.getCoverageSampleDimensions(CatalogBuilder.java:1118)
	at org.geoserver.catalog.CatalogBuilder.buildCoverageInternal(CatalogBuilder.java:1006)
	at org.geoserver.catalog.CatalogBuilder.buildCoverage(CatalogBuilder.java:932)
	at org.geoserver.catalog.CatalogBuilder.buildCoverage(CatalogBuilder.java:893)
	at org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:392)
	... 121 more
Does anyone have an idea what’s the problem with this GPKG?
I’m using GeoServer 2.28.2
Thanks, Manuel
