Georchestra problem
Hello,
I have a problem connecting mapstore and geonetwork.
When I create a WMS metadata record, it works and VFS for some reason does not work. Even if we validate the metadata record, it is valid.
I want to ask, can these problems be caused by an older version of georchestra? We are currently using version :This GeoServer instance is running version 2.22.2-georchestra
If you can think of anything else, I would be happy for any advice and help.
Thank you
While I would be happy to help you, the information you gave is not sufficient to do that properly. Things that can help others figure out a solution:
  • an error message either as text or screenshot
  • a public URL making it possible to reproduce the error easily
  • versions of GeoNetwork and GeoServer used
