GeoServer 2.25.5 artifacts ready for testing
the GeoServer 2.25.5 release artifacts are ready for early testing:
https://build.geoserver.org/view/release/job/geoserver-release/155/artifact/distribution/2.25.5/
I gave the bin package a quick spin on Linux, Java 17, it worked fine. Anyone else wants to give it a go?
@aaime-geosolutions, I took a quick look on Jenkins, hoping to trigger a build for the 2.25.x docker image, so that I could test it, but it appears as though the last successful build was 27 days ago, and the error is:
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
How do I fix this so that I can test for you?
Peter
Unsure, I had no part in setting up that build… the build should be triggered as part of the release-publish step, I’m not sure it would work at all if GeoServer 2.25.5 is not released before it’s run?
First time I look at it, but it seems relatively straighforward:
By the looks of release.sh, it seems it relies on having GeoServer already published on SF, but I may be wrong.
By the way, I reached out to Alessandro Parma, he re-started the docker service.
It’s set up to start automatically, but on the last server restart, for unknown reasons, it failed to do so.
Yes, absolutely, that is the case for 2.25.5 (release)
However, I wanted to trigger it for 2.25.x (nightly), which I have just done successfully, thanks.
I have now got docker 2.25.x running with my data, checking it out. FYI, the revisions should match your Jenkins jobs exactly:
About GeoServer
General information about GeoServer.
Build Information
GeoServer Version
2.25-SNAPSHOT
Git Revision
c1d6a3ca037671f91cffb4cff55193a7ab027896
Build Date
18-Dec-2024 16:58
GeoTools Version
31-SNAPSHOT (rev ca771be56a6a0f5fa0f011ef3e0c90a8a95b2f42)
GeoWebCache Version
1.25-SNAPSHOT (rev 84f2fc0dc1398e1fe100d06c52226b992447de08/84f2fc0dc1398e1fe100d06c52226b992447de08)
Everything working as expected for me - using the 2.25.x docker image above.
Thanks for testing Peter. Publishing underway, release announcements tomorrow
