geoserver 2.28.4 cssStyleHandler exception w/ CSS plugin
I updated to GeoServer 2.28.4 and when I add the CSS Styling extension, I get the following error (below). I can get around it with:
GEOSERVER_DATA_DIR_LOADER_ENABLED=false
but is there another way to fix it?
The 2 extensions I’m using are:
geoserver-2.28.4-css-plugin.zip (if I remove these jars, the problem goes away)
geoserver-2.28.4-feature-pregeneralized-plugin.zip
GEOSERVER DATA DIR is /geoserver/data_dir
2026-09-10 17:44:40.678:INFO :oejs.Server:main: jetty-10.0.25; built: 2025-03-13T00:02:39.342Z; git: 96cc25d2f26c3fb61444b801be87640e59cf380e; jvm 17.0.1+12-39
2026-09-10 17:44:40.920:INFO :oejdp.ScanningAppProvider:main: Deployment monitor [file:///geoserver/webapps/]
2026-09-10 17:44:42.791:INFO :oejw.StandardDescriptorProcessor:main: NO JSP Support for /geoserver, did not find org.eclipse.jetty.jsp.JettyJspServlet
2026-09-10 17:44:42.817:WARN :oeju.DeprecationWarning:main: Using @Deprecated Class org.eclipse.jetty.servlet.listener.ELContextCleaner
2026-09-10 17:44:42.976:INFO :oejss.DefaultSessionIdManager:main: Session workerName=node0
17:44:45 CONFIG [geoserver.logging] - Logging policy: Log4J2
10 Sep 17:44:47 CONFIG [geoserver.logging] - Log4j 2 configuration set to DEFAULT_LOGGING.xml
2026-09-10 17:44:47.604:INFO :oejshC.geoserver:main: Initializing Spring root WebApplicationContext
10 Sep 17:44:56 CONFIG [org.geoserver] - GeoServer configuration lock is enabled
10 Sep 17:45:00 CONFIG [gwc.config] - Will look for ‘geowebcache.xml’ in directory ‘/geoserver/data_dir/gwc’.
10 Sep 17:45:01 WARN [config.XMLConfiguration] - GWC configuration validation error: cvc-elt.1.a: Cannot find the declaration of element ‘gwcConfiguration’.
10 Sep 17:45:01 WARN [config.XMLConfiguration] - Will try to use configuration anyway. Please check the order of declared elements against the schema.
10 Sep 17:45:02 ERROR [config.datadir] - Error preloading org.geoserver.catalog.StyleHandler
org.springframework.beans.factory.BeanCurrentlyInCreationException: Error creating bean with name ‘cssStyleHandler’: Requested bean is currently in creation: Is there an unresolvable circular reference?
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.beforeSingletonCreation(DefaultSingletonBeanRegistry.java:355)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:227)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:334)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:209)
at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1171)
at org.geoserver.platform.GeoServerExtensions.getBean(GeoServerExtensions.java:249)
at org.geoserver.platform.GeoServerExtensions.extensions(GeoServerExtensions.java:143)
at org.geoserver.platform.GeoServerExtensions.extensions(GeoServerExtensions.java:281)
at org.geoserver.config.datadir.DataDirectoryGeoServerLoader.preLoadExtensions(DataDirectoryGeoServerLoader.java:301)
at org.geoserver.config.datadir.DataDirectoryGeoServerLoader.initializeDependencies(DataDirectoryGeoServerLoader.java:279)
at org.geoserver.config.datadir.DataDirectoryGeoServerLoader.loadCatalog(DataDirectoryGeoServerLoader.java:125)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitializationCatalog(GeoServerLoader.java:321)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:272)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:63)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1796)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:620)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:542)
at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:336)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:234)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:330)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:113)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:695)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:189)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1372)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1222)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:582)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:323)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeansOfType(DefaultListableBeanFactory.java:673)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeansOfType(DefaultListableBeanFactory.java:661)
at org.springframework.context.support.AbstractApplicationContext.getBeansOfType(AbstractApplicationContext.java:1317)
at org.geowebcache.GeoWebCacheExtensions.getBeansNamesOrderedByPriority(GeoWebCacheExtensions.java:151)
at org.geowebcache.GeoWebCacheExtensions.extensions(GeoWebCacheExtensions.java:99)
at org.geowebcache.config.XMLConfiguration.getConfiguredXStreamWithContext(XMLConfiguration.java:430)
at org.geowebcache.config.XMLConfiguration.getConfiguredXStreamWithContext(XMLConfiguration.java:338)
at org.geowebcache.config.XMLConfiguration.loadConfiguration(XMLConfiguration.java:308)
at org.geowebcache.config.XMLConfiguration.loadConfiguration(XMLConfiguration.java:299)
at org.geowebcache.config.XMLConfiguration.afterPropertiesSet(XMLConfiguration.java:802)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1863)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1800)
at org.geowebcache.GeoWebCacheExtensions.configurations(GeoWebCacheExtensions.java:193)
at org.geowebcache.grid.GridSetBroker.getConfigurations(GridSetBroker.java:217)
at org.geowebcache.grid.GridSetBroker.afterPropertiesSet(GridSetBroker.java:62)
at org.geoserver.community.css.web.CssHandler.(CssHandler.java:79)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
… suppressed 2 lines
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:213)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:117)
at org.springframework.beans.factory.support.ConstructorResolver.instantiate(ConstructorResolver.java:302)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:287)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:955)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:932)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:591)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:399)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:278)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:103)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:22)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:1049)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:624)
at org.eclipse.jetty.server.handler.ContextHandler.contextInitialized(ContextHandler.java:984)
at org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:740)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:392)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1304)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:901)
at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:306)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:532)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:93)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:40)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:183)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:516)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:151)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:210)
at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:442)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:61)
at org.eclipse.jetty.util.Scanner$DiscreteListener.pathAdded(Scanner.java:284)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:896)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:862)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:769)
at org.eclipse.jetty.util.Scanner.startScanning(Scanner.java:658)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:630)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:171)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:121)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:182)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:605)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:246)
at org.eclipse.jetty.server.Server.start(Server.java:470)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:89)
at org.eclipse.jetty.server.Server.doStart(Server.java:415)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1936)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:229)
at org.eclipse.jetty.start.Main.start(Main.java:528)
at org.eclipse.jetty.start.Main.main(Main.java:76)
it has been fixed here: Jira
When I stumbled into it, I got the annoying log, but the CSS styling was working anyways.
The fix will be in the next 3.0.2 release… I just scheduled a backport to 2.28.x too, let’s see if it builds properly:
Not sure when the next 2.28.x release will be, we are thinking of keeping that series alive for a bit longer but the release cadence will be slower than regular releases (the official support period for 2.28.x ends this month, GeoSolutions is sponsoring a few more releases at a lower cadence and no specific calendar).
