GeoServer 2.28.4 released
Hi GeoServer users
We know that you are on the edge of your seats, eagerly awaiting GeoServer 3.0.0, due in a few days time, but we are still looking after the previous 2.28 series too!
This is a special stable release of 2.28.4 (it would normally have switched into maintenance 6 months after its initial release).
For those organisations still on previous series 2.27 and earlier, we really recommend that you upgrade to this version, to make the transition to GeoServer 3 smoother. And then upgrade to 3.0.0, as soon as you are comfortable.
See the blog posts:
GeoServer 2.28.4 has been released: GeoServer 2.28.4 Release
We apologise once again that we are not yet able to provide a Windows Installer.
In conjunction with GeoTools 34.4 GeoTools: GeoTools: GeoTools 34.4 released and GeoWebCache 1.27.5 Release GeoWebCache 1.28.4 · GeoWebCache/geowebcache · GitHub
Regards
Peter
Hello, thank you very much for the new release!
However, could it be that push to the Nexus Repository failed for some reason?
Hi @Tommy , which component are you talking about?
I think it’s the repo.osgeo.org Nexus repository (e.g., Index of /org/geoserver/gs-main)
Thanks Steve & Tommy, I’ll investigate. There definitely were problems with the 2.28 release, after the 3.0 (-RC) changes.
Peter
@Tommy thanks so much for picking this up, the expected gs-main files should now be there: Index of /org/geoserver/gs-main/2.28.4
[GEOS-12093] Fix publish_release.sh: version-gate GS3+ merge workflow by petersmythe · Pull Request #9525 · geoserver/geoserver · GitHub
Peter
Hello @Peter, thank you, now it seems perfect.
