Hi I am trying to serve the geoserver content behind a nginx https server, the config is the following, my idea is to server all content in https and restrict the access to the admin area to some IPS (allow_pro.conf)
On the first block I redirect all the requests to https so no plai content goes through
server {
listen 80;
server_name geoserverpub.example.com;
location / {
return 301 https://$host$request_uri;
server {
listen 443;
access_log /var/log/nginx/geoserverpub.access.log upstreamlog;
location /geoserver/ {
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Host $http_host;
proxy_set_header X-NginX-Proxy true;
proxy_pass http://geoserverpub.example.net:8080/geoserver/;
proxy_redirect off;
location /geoserver/web/ {
proxy_redirect off;
proxy_pass http://geoserverpub.example.net:8080/geoserver/web/;
include /etc/nginx/snippets/allow_pro.conf;
The problem is that many of the links inside the html are non relative and I get alerts about the insecure content, for example the links to http://geoserverpub.example.com/geoserver/j_spring_security_check
On many web applications you can define the public URL for the service, so the URL will work behind a web server.
Is that possible with geoserver?
I’ve seen some related issues but couldn’t find a definite answer and most of them are quite old:
