Hi Simone,
thanks for your answer!
I think until next week I can give you sample data.
The data which produces the mistakes at the end of this email is not public, sorry.
The image (geotiff) has the size of 200 mega byte.
geoserver try to include the image for one hour. After that he produces the following mistakes.
hardware:
cpu: 1.1 GHz
main memory: 768 MB
software:
tomcat: 5.0.28
java: 1.4.2_07
Do you think the problem is based on the situation that tomcat needs more memory to load the data?
I´ve read something that tomcat has only 64 mb memory for working by default. I´ve done some experiments with the following commands
(without success) ... wrong way?
export JAVA_OPTS="-Xms128m -Xmx256m"
export CATALINA_OPTS="-Xms128m -Xmx256m"
Today I have tested a small geotiff (650 kb). Works fine!
Greetings, Lars
HTTP Status 500 -
*type* Exception report
*message*
*description* _The server encountered an internal error () that prevented it from fulfilling this request._
*exception*
javax.servlet.ServletException
org.apache.struts.action.RequestProcessor.processException(RequestProcessor.java:545)
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:486)
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274)
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482)
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:525)
javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
*root cause*
java.lang.NullPointerException
org.vfny.geoserver.action.data.DataFormatsEditorAction.execute(DataFormatsEditorAction.java:240)
org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:484)
*note* _The full stack trace of the root cause is available in the Apache Tomcat/5.0.28 logs.
_
*from localhost_log*
2005-06-29 19:43:09 StandardWrapperValve[action]: Servlet.service() for servlet action threw exception
at org.vfny.geoserver.action.data.DataFormatsEditorAction.execute(DataFormatsEditorAction.java:240)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:484)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:525)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:237)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:157)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:214)
at org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:104)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:520)
at org.apache.catalina.core.StandardContextValve.invokeInternal(StandardContextValve.java:198)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:152)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:137)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:118)
at org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:929)
at org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java:160)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:799)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:705)
at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:577)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:683)
at java.lang.Thread.run(Thread.java:534)
