[Geoserver-devel] 2.6.0 release artefacts available
Please grab a copy from http://docs.geotools.org/stable/userguide/library/data/excel.html and check they work on your machine type.
Ian
Ian Turton
As a Jedi once said "that's not the link you're looking for"
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Whoops, try - http://ares.boundlessgeo.com/geoserver/release/2.6.0
I keep forgetting I use windows at work and have to hit ctrl-C to copy.
Ian
On 29 September 2014 08:36, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ian Turton
As a Jedi once said “that’s not the link you’re looking for”
Ing. Andrea Aime
@geowolf
Technical Lead
I tried to build the src, and failed.
bradh@anonymised.com:~/geoserver26/geoserver-2.6.0$ mvn install
[INFO] Scanning for projects...
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project org.geoserver:geoserver:2.6.0 (/home/bradh/geoserver26/geoserver-2.6.0/pom.xml) has 14 errors
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/platform of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/main of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/security of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/wcs of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/wcs1_0 of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/wcs1_1 of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/wcs2_0 of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/wfs of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/wms of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/kml of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/ows of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/gwc of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/rest of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR] Child module /home/bradh/geoserver26/geoserver-2.6.0/restconfig of /home/bradh/geoserver26/geoserver-2.6.0/pom.xml does not exist
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
I think the problem is that the entries in the modules stanza are
missing the gs- prefix:
bradh@anonymised.com:~/geoserver26/geoserver-2.6.0$ ls -a
. community gs-gwc gs-main gs-platform gs-restconfig gs-wcs gs-wcs1_1 gs-wfs pom.xml web
.. extension gs-kml gs-ows gs-rest gs-security gs-wcs1_0 gs-wcs2_0 gs-wms VERSION.txt
Brad
Hum… I’m having memories of having seen this one already, and
we discussed about it, and decided we should just point people to the zip file
generated by Github instead… which is not yet available, because the deploy
job still have not run.
Jody/Justin, do you remember? Am I getting confused?
[INFO] Scanning for projects…
[ERROR] The build could not read 1 project → [Help 1]
[ERROR]
[ERROR]
[ERROR]
… extension gs-kml gs-ows gs-rest gs-security gs-wcs1_0 gs-wcs2_0 gs-wms VERSION.txt
Brad
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Yeah I am sure the release script may still be trying to make the invalid project download.
The download template for 2.6.x points to the github tag.
See links here http://geoserver.org/release/dev/
When creating a new download page there are several layouts to choose from:
Example use:
Jody Garnett
On Tue, Sep 30, 2014 at 10:16 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
[ERROR]
[ERROR]
[ERROR]
Brad
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, 30 Sep 2014 07:16:03 PM Andrea Aime wrote:
Hum... I'm having memories of having seen this one already, and
file
generated by Github instead... which is not yet available, because the
deploy
I think this would be OK. It would be better not to release the -src.zip if it
doesn't build though.
Brad
TLDR: got a DMG with a bit of hacking, but it does not include a JRE
Tried using the bin and mac download, guess I do not know the steps for including a runtime.
$ ./build.sh
Buildfile: /Users/jody/Downloads/geoserver-2.6.0-mac/build.xml
clean:
bootstrap:
[get] Getting: http://repo.boundlessgeo.com/main/com/oracle/appbundler/1.0ea/appbundler-1.0ea.jar
[get] To: /Users/jody/Downloads/geoserver-2.6.0-mac/lib/appbundler-1.0ea.jar
[get] Not modified - so not downloaded
[get] Getting: http://central.maven.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar
[get] To: /Users/jody/Downloads/geoserver-2.6.0-mac/lib/ant-contrib-1.0b3.jar
init:
build:
[mkdir] Created dir: /Users/jody/Downloads/geoserver-2.6.0-mac/target
[unzip] Expanding: /Users/jody/Downloads/geoserver-2.6.0-mac/geoserver-2.6.0-bin.zip into /Users/jody/Downloads/geoserver-2.6.0-mac/target
build-console:
[mkdir] Created dir: /Users/jody/Downloads/geoserver-2.6.0-mac/target/console
[javac] /Users/jody/Downloads/geoserver-2.6.0-mac/build.xml:59: warning: ‘includeantruntime’ was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 4 source files to /Users/jody/Downloads/geoserver-2.6.0-mac/target/console
BUILD FAILED
/Users/jody/Downloads/geoserver-2.6.0-mac/build.xml:52: The following error occurred while executing this line:
/Users/jody/Downloads/geoserver-2.6.0-mac/build.xml:59: /Users/jody/Downloads/geoserver-2.6.0-mac/target/geoserver-2.6.0-mac/geoserver-2.6.0 does not exist.
Looking at that we have a bad regex … based on unzipping the files directly resulting in the path /Users/jody/Downloads/geoserver-2.6.0-mac/target/geoserver-2.6.0 parsing out a gs.version of “2.6.0-mac/geoserver-2.6.0”.
Going for a simple rename of the directory and I can produce a DMG.
Jody
Jody Garnett
On Mon, Sep 29, 2014 at 7:51 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Don’t see a DMG yet, not really in position to build one until this evening.
Jody Garnett
On Mon, Sep 29, 2014 at 12:44 AM, Ian Turton <ijturton@anonymised.com> wrote:
Ian
Slashdot TV. Videos for Nerds. Stuff that Matters.
http://pubads.g.doubleclick.net/gampad/clk?id=160591471&iu=/4140/ostg.clktrk
Ian Turton
On Mon, Sep 29, 2014 at 9:18 AM, Ian Turton <ijturton@anonymised.com…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Okay, it grabs my system JDK (not JRE). Updating that to the latest works fine …
I cannot figure out how to upload to ares, so uploading to source forge now:
http://sourceforge.net/projects/geoserver/files/GeoServer/2.6.0/
Jody Garnett
On Tue, Sep 30, 2014 at 10:07 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
$ ./build.sh
clean:
bootstrap:
init:
build:
build-console:
BUILD FAILED
Jody
Jody Garnett
Jody Garnett
Ian
On 29 September 2014 08:36, Andrea Aime <andrea.aime@anonymised.com…> wrote:
Ian Turton
Ing. Andrea Aime
@geowolf
Technical Lead
