Recently I have been experimenting with the notion of a rest dispatcher callback, the same way we have a callback for ows based services.
Attached is the first cut of the patch. Let me know what you think. You will probably note in the patch that the exception() and finished() callbacks are not called. That is because I would like to build off of a recent patch from Andrea that involves a subclass of ServletConverter and invoke the callback methods there.
A couple of other questions. Should I throw together a proposal for this? Also I eventually would like to backport this to 2.1.x. But can hold off on that for a while and let it sit on trunk.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
(attachments)
rest_dispatcher.patch (3.7 KB)
On Mon, Jan 31, 2011 at 7:20 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
methods there.
Sounds good to me. If you want just go ahead and also merge in the patch
I was talking about yesterday
Ing. Andrea Aime
Technical Lead
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Cool, callback and servlet converter committed on trunk. Will backport to 2.1.x after it has a chance to settle.
On Mon, Jan 31, 2011 at 2:18 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
methods there.
Ing. Andrea Aime
Technical Lead
fax: +39 0584962313
Justin Deoliveira
