[Geoserver-devel] About the build failures in wfsv
the build failures in the wfsv module are due to the
fact the tests are enabled (the $home/.geoserver/wfsv.properties file is there) but the connection is failing, probably because the db is not there:
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/surefire-reports/org.geoserver.wfsv.HistoryRelatedTest.txt
Anything I can do to help fix this?
