[Geoserver-devel] Added wps-jdbc to the community build
Andrea,
I have added wps-jdbc to the community build as we already had an active assembly descriptor and were shipping an empty plugin zip file. I expect that this was an oversight:
https://github.com/geoserver/geoserver/commit/cd7b4deb6737993af870e3205281c6fbf2e8936b
The alternative solution if you do not want this plugin published is to revert this fix and remove the assembly descriptor from community/pom.xml.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
On Wed, Mar 2, 2016 at 11:22 PM, Ben Caradoc-Davies <ben@anonymised.com>
wrote:
Andrea,
Add wps-jdbc to the community build · geoserver/geoserver@cd7b4de · GitHub
Yep, that was most likely an oversight, thanks for fixing it
GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
