A user from Guatemala asked whether we could add the bellow projection to the standard distribution.
I guess that'd imply adding it to the user_pojections in the release configuration, since adding it to the actual epsg database might be more problematic?
what do you think?
Gabriel
-------- Original Message --------
Subject: [geoserver-es:229] Proyeccion GTM par aguatemala
Date: Fri, 15 Jan 2010 13:01:22 -0800 (PST)
Reply-To: geoserver-es@anonymised.com
To: GeoServer en EspaƱol <geoserver-es@anonymised.com>
Saludos cordiales
Estimado Gabriel adjunto el WKT de la proyeccion que utilizamos para
guatemala la GTM , la cual me recomendaron enviarte para ver si se
podia incluir en la distribucion de geoserver
42500=PROJCS["GTM",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID
["WGS_1984", 6378137.0, 298.257223563]],PRIMEM["Greenwich", 0.0],UNIT
["degree", 0.017453292519943295],AXIS["Longitude", EAST],AXIS
["Latitude", NORTH]],PROJECTION["Transverse_Mercator"],PARAMETER
["central_meridian", -90.5],PARAMETER["latitude_of_origin",
0.0],PARAMETER["scale_factor", 0.9998],PARAMETER["false_easting",
500000.0],PARAMETER["false_northing", 0.0],UNIT["m", 1.0],AXIS["x",
EAST],AXIS["y", NORTH]]
Gracias mil
atte
Walter Giron
Guatemala
Gabriel Roldan
OpenGeo - http://opengeo.org
(attachments)
Attached Message Part (376 Bytes)
