Following up on Andreas comments last week about adding more version info to our builds. I would like to follow up on this. Three important bits to have would be:
- the primary version (from the pom)
- the svn revision (from the svn-revision maven plugin)
- the build timestamp (generated via some ant scripting)
The idea would be to (a) make the info available in a file contained in all artifacts and (b) add the info to the ui.
For (b) I was thinking the “About” page would make sense. And would look something like:
https://skitch.com/jdeolive/ryqak/geoserver-about-geoserver
Any objections? Any other info we should also include?
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
On Mon, Nov 15, 2010 at 8:43 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
would be:
* the primary version (from the pom)
* the svn revision (from the svn-revision maven plugin)
* the build timestamp (generated via some ant scripting)
For (b) I was thinking the "About" page would make sense. And would look
something like:
Yup, works for me.
We should do the same for Geotools. Arguably, start there.
Possibly we could put those information in META-INF, I believe maven
is already generating some file there
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
On Mon, Nov 15, 2010 at 1:33 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
would be:
something like:
Yup, works for me.
Agreed. And ideally the geoserver revision output would include the geotools one. I tried a couple of things with minimal success though. I was able to add the svn revision info to the manifest but nothing else. Maybe breaking out a custom maven plugin…? Will try some more tomorrow but if anyone has any ideas i am all ears.
Ing. Andrea Aime
fax: +39 0584962313
Justin Deoliveira
On Tue, Nov 16, 2010 at 5:21 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
wrote:
> Hi all,
> info to
> have
> would be:
> all
> something like:
Yup, works for me.
out a custom maven plugin..? Will try some more tomorrow but if anyone has
Can't offer ideas, but maybe next time share your patches, someone
might have a look and provide some hints or find a boring hour and give
it a crack
Ing. Andrea Aime
fax: +39 0584962313
