[Geoserver-devel] Allowing more control on WMS capabilties generation
I’m looking into a case where we would like to have more control over the capabilities
document generated by GeoServer, without having to fork off its code, or to interfere
with other plugins already customizing it (e.g. the INSPIRE one).
Now, the requirements would be, more or less, to:
I might have other additions of bits to control down the line, but wanted to check about
the overall direction first.
It seems to me we already have the extension point, the above cited ExtendedCapabilitiesProvider,
https://github.com/geoserver/geoserver/blob/master/src/wms/src/main/java/org/geoserver/wms/ExtendedCapabilitiesProvider.java ,
and that we just need to add more callback methods, for example:
void customizeRootSrsList(Set srs);
void customizeFormats(String operationName, Set formats);
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Wed, Jan 21, 2015 at 4:17 PM, Andrea Aime <andrea.aime@anonymised.com>
wrote:
void customizeRootSrsList(Set<String> srs);
void customizeFormats(String operationName, Set<String> formats);
About the formats, it makes more sense to implement ExtensionFilter and
remove
the formats we don't want direclty in GeoServerExtensions.
Anyways, the general question on direction (and srs list customization)
still stands
GeoSolutions for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
