[Geoserver-devel] Any documentation for the importer REST api?
the importer module has a REST API, which apparently can do the same as the GUI, and more,
in a more automation friendly way.
However, there is no documentation, there is a few tests, but they look a bit programmatic
and the workflow they suggest seems sort of a multi-step one, something like:
  • create a import
  • populate its tasks
  • actually start the import
  • monitor its progress
But… well, I could be misunderstanding.
Soo… is there any published doc about the topic?
Or someone will have to reverse engineer what’s going on starting from the tests?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea,
On Thu, Feb 12, 2015 at 12:31 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Correct. One major limitation of the wicket UI for the importer is that the data must be local.
  • create a import
Correct - it is a multi-step process. The idea is that a user might upload a variety of data in a single zip file. This results in multiple tasks that may or may not need configuration.
There is some in the docs directory - it may be outdated, however.
I had done some work to create a java client to make descriptive test cases easier to write and execute but never completed it, but…
There is also a client library here and an integration test suite with a narrower focus: https://github.com/boundlessgeo/gsimporter
Hope that helps
Ian Schneider
Software Engineer | Boundless
ischneider@anonymised.com…3839…
1-877-673-6436
@boundlessgeo
On Thu, Feb 12, 2015 at 6:33 PM, Ian Schneider <ischneider@anonymised.com>
wrote:
But.. well, I could be misunderstanding.
Soo... is there any published doc about the topic?
Doc doc... oh!
Did not see this one :slight_smile:
Interesting, I'll see if/how I can merge that into our docs
Or someone will have to reverse engineer what's going on starting from
the tests?
cases easier to write and execute but never completed it, but...
narrower focus: GitHub - planetfederal/gsimporter
Thanks for the link
GeoSolutions for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Feb 16, 2015 at 6:47 PM, Andrea Aime <andrea.aime@anonymised.com>
wrote:
Doc doc... oh!
geoserver/src/extension/importer/doc at main · geoserver/geoserver · GitHub
Ok, so a few questions if I may.
When creating a new import with proposed id with PUT, the code says:
*"Create import with proposed id <importId>. If the proposed id is ahead of
the current (next) id, the current id will be advanced. If the proposed id
is less than or equal to the current id, the current will be used. This
allows an external system to dictate the id management."*
Soo... basically the id will be accepted only if it is greater than the
current id, and the current will be updated to it, right?
Besides that, one thing standing out is that the rst version of the doc
says tasks has items, whilst the markdown
one says tasks has layers, directories, files, but no items (and also cites
the transforms, nice)
Looking at the rest mappings declared in the applicationContext.xml it
looks like items are not there, but layers
are, so the API reference table in the rst document needs to be updated
One thing that I was wondering is, is it not possible to just POST the
whole json/xml tree describing
the import, its tasks, it transforms and whatnot in a single shot? Say for
example that the upload
(maybe large) was managed out of band with a different tool (FTP,
resumable/chunked HTTP),
I see no reason for making all this little calls to stand up a complex
import.
Am I missing something?
Ing. Andrea Aime
@geowolf
Technical Lead
another one. It seems the representation of resources is stuck to json, or at least,
it doe not change when changing the suffix of the resource to .xml.
This is inconsistent to the GeoServer rest api, I think it should be reported as a bug
(also given the code is using the geoserver resource representation for some of its
api bits)
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
On Mon, Feb 16, 2015 at 11:34 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
I only realized the other day when you asked that these don’t get included into the doc build.
Right.
I cannot recall how we ended up w/ two docs (Justin?) but the item concept is now removed.
I believe it’s possible but have not tried.
The API is complex, agreed. As for the little calls, performance wise, they are generally not noticeable. Usability wise, annoying, yes.
The idea was/is to support an interactive workflow:
user: here’s my data…
gs: ok, I see you’ve given me 3 shapefiles, one with a bad/missing projection and something I don’t recognize/support
user: ok, ignore that other thing and use 4326 for that bad shapefile
user: now that I see my ‘time’ attribute is actually encoded as text, convert that to a date
user: oh yeah, and import that 1st shapefile into the database but call it something else and create an index on that attribute
If you know what you want to do ahead of time, this should ideally be supported as well.
There was initially more ‘post’ import functionality present at one point (layer configuration, etc.) but this seems like it belongs in the standard catalog API.
Hope that explains some.
On Mon, Feb 16, 2015 at 6:47 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Doc doc… oh!
https://github.com/geoserver/geoserver/tree/master/src/extension/importer/doc
Interesting, I’ll see if/how I can merge that into our docs
“Create import with proposed id . If the proposed id is ahead of the current (next) id, the current id will be advanced. If the proposed id is less than or equal to the current id, the current will be used. This allows an external system to dictate the id management.”
Soo… basically the id will be accepted only if it is greater than the current id, and the current will be updated to it, right?
Besides that, one thing standing out is that the rst version of the doc says tasks has items, whilst the markdown
one says tasks has layers, directories, files, but no items (and also cites the transforms, nice)
Looking at the rest mappings declared in the applicationContext.xml it looks like items are not there, but layers
One thing that I was wondering is, is it not possible to just POST the whole json/xml tree describing
the import, its tasks, it transforms and whatnot in a single shot? Say for example that the upload
(maybe large) was managed out of band with a different tool (FTP, resumable/chunked HTTP),
I see no reason for making all this little calls to stand up a complex import.
Ian Schneider
1-877-673-6436
@boundlessgeo
