this failure seem to be again related to code memory mapping files (simple rule of thumb for Windows, never memory map anything, as there is no way to release it and it keeps the file locked):
Caused by: java.io.IOException: Could not write catalog to target\app-schema-mock5080864842203962709data\catalog.xml
at org.geoserver.data.CatalogWriter.write(CatalogWriter.java:257)
at org.geoserver.test.AbstractAppSchemaMockData.setUpCatalog(AbstractAppSchemaMockData.java:342)
... 34 more
Caused by: java.io.FileNotFoundException: target\app-schema-mock5080864842203962709data\catalog.xml (The requested operation cannot be performed on a file with a user-mapped section open)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:221)
at java.io.FileOutputStream.<init>(FileOutputStream.java:171)
at org.geoserver.data.CatalogWriter.write(CatalogWriter.java:252)
... 35 more
Rings a bell to anyone?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
