[Geoserver-devel] ArcSDE raster URL syntax
Yup. The problem is that in order to allow arbitrary parameter passing
from the geoserver UI to the geotools backend (which takes an Object as
a coverageStore creation parameter) everything gets turned into a File.
So on unix, the following URL gets turned into a file with the following
path:
URL("sde://saul:saul@anonymised.com/#blah") -> File -> String =
sde:/saul:saul@anonymised.com/#blah
On windows, the same set of translations leads to
sde:\saul:saul@anonymised.com\#blah
Blech.
Bob, you should make this JIRA and I'll go and try to change the parsing
code to work on windows too.
--saul
On Fri, 2007-10-26 at 13:24 -0700, Bob Nutsch wrote:
Just a note that I found what is causing the problem.
When I use the GeoServer GUI and enter
sde://bnutsch:password@anonymised.com:5151/#NDHUB.AERIALPHOTOS_6INCH
I get the 'invalid url' error that I first reported.
When I manually edit the catalog.xml and enter this info, e.g.,
    <format namespace = "NDHUB" enabled = "true" id = "NDHUB_aerialphotos" >
       <type>ArcSDE Raster</type>
<url>sde://bnutsch:password@anonymised.com:5151/#NDHUB.AERIALPHOTOS_6INCH</url>
    </format>
I get a crash. In the logs I see:
26 Oct 14:48:45 WARN [org.geotools.arcsde.gce] - connectiong via file-hack
to ArcSDE Raster: sde:\bnutsch:pass@anonymised.com:5151\#NDHUB.AERIALPHOTOS_6INCH
26 Oct 14:48:45 WARN [org.apache.struts.action.RequestProcessor] - Unhandled
Exception thrown: class java.lang.IllegalArgumentException
26 Oct 14:48:45 ERROR
[org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/geoserver].[action]]
- Servlet.service() for servlet action threw exception
java.lang.IllegalArgumentException: ArcSDE Raster URL must be of the form
sde://user:pass@anonymised.com:port/[dbname]#rasterTableName -- Got
  at
org.geotools.arcsde.gce.ArcSDERasterGridCoverage2DReader.sdeURLToConnectionConfig(ArcSDERasterGridCoverage2DReader.java:453)
  at
org.geotools.arcsde.gce.ArcSDERasterGridCoverage2DReader.setupConnectionPool(ArcSDERasterGridCoverage2DReader.java:604)
  at
org.geotools.arcsde.gce.ArcSDERasterGridCoverage2DReader.<init>(ArcSDERasterGridCoverage2DReader.java:172)
>From visiting with Saul off-line, it appears that this is a case of windows
- unix slash directions.
I plan to try my hand at entering this bug into jira.codehaus.org
Regards, Bob
Bob Nutsch wrote:
> Hi,
> I'm trying to access raster data from ArcSDE 9.2 (with has a backend of
> Oracle 10g). I select 'ArcSDE Raster Format' from the list when starting
> to set up a new coverage store. I supply a Coverage Data Set ID and then
> click on the New button.
> I must be doing something wrong for the URL syntax because after entering
> the URL information and clicking on the Submit button I get the following
> on the left side of the GeoServer admin page:
> "Invalid url:
> 'sde://myuser:mypwd@anonymised.com:5198/#NDHUB.NGS_DRG24K;LZERO_ORIGIN_TILE=0,0'
> for format type:'ArcSDE Raster'.
> I've looked at the example shown on
> http://docs.codehaus.org/display/GEOTDOC/ArcSDE+DataStore. I'm too dumb
> to figure out what I'm missing. :slight_smile:
> Here's my information:
> User: myuser
> Pwd: mypwd
> Server: myserver.state.nd.us
> ArcSDE instance: 5198
> raster layer: NDHUB.NGS_DRG24K (where 'NDHUB' is the schema owner)
> There's something wrong with the syntax around the '#' area I think. It's
> been my experience that when using ArcSDE with Oracle, there is not a
> database or instance name, simply the server and port number (along with
> the userid and password). For SQL Server, I would enter the name of the
> database but there is no database name for Oracle. So when using ESRI
> tools I generally leave the database name blank or enter a "#" for that
> field. I'm thinking that perhaps this is the issue with the URL that I'm
> using, but I'm not sure.
> Any thoughts would be greatly appreciated!
> Thanks, Bob
View this message in context: http://www.nabble.com/ArcSDE-raster-URL-syntax-tf4635131.html#a13434681
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Geoserver-devel mailing list
path:
Blech.
--saul
Hi list,
I get same error at my geoserver 2.0 (nightly build) UI at windows.
I found this:
http://jira.codehaus.org/browse/GEOS-1447?page=com.atlassian.streams.streams-jira-plugin%3Aactivity-stream-issue-tab
. In fact of the error message I guess the patch is not commited into my
nightly build.
Could anyone perhaps say how to fix this issue?
Thanks.
best regards
Sarah
View this message in context: http://old.nabble.com/ArcSDE-raster-URL-syntax-tp13236680p27128809.html
