[Geoserver-devel] Attempting to upgrade Marlin, WIP and request for assistance
during the GeoServer workshops at FOSS4G EU people showed up
with Java 17 or 21 by default, and we know the bin package does not work in that context.
I have made a quick attempt at updating to the latest, and using the system module (Java 11+) to integrate it, here:
https://github.com/geoserver/geoserver/pull/7760
It’s a draft pull request from a shared branch, help welcomed.
I’ve also created a ready to test bin package for those that want to try it out:
Let me know if it works for you, on which OS and Java, and if not, let me know anyways, extra points for those that can also provide a suggestion on how to fix the startup.sh/startup.bat to make it work:
https://www.dropbox.com/scl/fi/yw8rsp1n3hx4vszyxmne7/geoserver-2.26-SNAPSHOT-bin-marlin-latest.zip?rlkey=852pcth2wvhpesp04f1yrixft&st=vn0tv0ne&dl=1
The objective is really simple: get GeoServer running in all LTS Java versions supported, across various OSs.
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
I’ve made some tests with the JVM’s I’ve installed and commented on the pr.
Andrea Aime
I’ve followed up with the review feedback, and prepared a new set of binaries to test out.
I’ve created an updated bin package, available here:
https://www.dropbox.com/scl/fi/z1l07yag53ffaxqr1umo3/geoserver-2.26-SNAPSHOT-bin-marlin-latest-p1.zip?rlkey=6o6rsf1oh89hppw17xauvalgt&st=rv3t3dil&dl=1
Can readers give it a spin, especially with java 17 and 21?
In particular, tester on Windows and OSX are most wanted (me and Gabriel gave it a spin on Ubuntu and Mint, other Linux distros could be interesting too).
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
I tested it on windows 11 with Java 17 and 21. Loads up fine and renders bitmaps on both platforms, but does not register in the Server Status page in either jvm:
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
I would like to test in a few containerized settings, but that requires a war. Andrea, if you got the time to supply a war I’ll be happy to test.
(attachments)
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Hi Peter,
thanks a lot for following up. So it’s good that it’s starting up, not so good that it’s not reporting the renderer.
I’m guessing the various add-opens are not being properly integrated in the startup command line…
Just to make sure, have you been testing the second link I’ve sent, the updated one? The file name ends with …-p1.zip
and the startup.bat, at line 142, has the following:
set JAVA_OPTS=%JAVA_OPTS% --add-exports=java.desktop/sun.awt.image=ALL-UNNAMED --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.lang.reflect=ALL-UNNAMED --add-opens=java.base/java.text=ALL-UNNAMED --add-opens=java.desktop/java.awt.font=ALL-UNNAMED --add-opens=java.desktop/sun.awt.image=ALL-UNNAMED --add-opens=java.naming/com.sun.jndi.ldap=ALL-UNNAMED --add-opens=java.desktop/sun.java2d.pipe=ALL-UNNAMED
Can any Windows batch file expert see if there is any error above? Maybe a lack of quoting?
(attachments)
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Hi Bjorn,
yes sure, here you are:
https://www.dropbox.com/scl/fi/3pew3szox44yfudqq8we6/geoserver-2.26-SNAPSHOT-war-p1.zip?rlkey=rzth2ajvq6wam2fmnb1e9yvc2&st=jozrhf4t&dl=1
Mind, in order to see the renderer show up in the “status” page, and avoid complaints in general from the JVM,
you’ll may have to add these to the JVM command line:
–add-exports=java.desktop/sun.awt.image=ALL-UNNAMED --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.lang.reflect=ALL-UNNAMED --add-opens=java.base/java.text=ALL-UNNAMED --add-opens=java.desktop/java.awt.font=ALL-UNNAMED --add-opens=java.desktop/sun.awt.image=ALL-UNNAMED --add-opens=java.naming/com.sun.jndi.ldap=ALL-UNNAMED --add-opens=java.desktop/sun.java2d.pipe=ALL-UNNAMED
(attachments)
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Hi Andrea,
I confirm that the file I’m running is named geoserver-2.26-SNAPSHOT-bin-marlin-latest-p1 and the exports line 142 matches / is the following:
(attachments)
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Hi Peter,
thanks, then the script is not really working as intended. Anyone with a Windows machine and some time to look at the script,
and make it work? My guess is that the JVM options are not being forwarded properly to the final command line starting up Jetty.
(attachments)
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Maybe dumb question but what are you expecting it to do? Is it the name of the Marlin renderer missing from the status page that is the problem?
Peter
(attachments)
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Hi Peter,
yes correct, that is the most visible problem. Other issues that can be expected are warnings in the logs.
With newer versions of Java it’s not unreasonable to expect some errors as well (not sure if Java 21
will already trigger them, or will just keep on complaining).
(attachments)
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
