Dear all,
apologies for the cross posting.
I would like to backport to GT 19.x:
and to GS 2.14.x:
- [ISSUE] https://osgeo-org.atlassian.net/browse/GEOS-8953
- [PR] https://github.com/geoserver/geoserver/pull/3124
… this fixes are in a gray zone between a fix and an improvement.
A significant part of the code are tests making sure geometries measures (M) are correctly outputted by GeoJSON, Shapefile and GML (non fast path) formats respecting the layer flag. I don’t foreseen any backwards compatibility issue.
Any objection ?
Kind regards,
Nuno Oliveira
Nuno Oliveira
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto,
gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that
is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or
use of this e-mail or the information herein by anyone
other than the intended recipient is prohibited. If you
have received this email by mistake, please notify
us immediately by telephone or e-mail.
